Arria10 AD9371 IIO Scope issues
Question asked by ACozma Employee on Apr 13, 2018
Latest reply on Apr 25, 2018 by DragosB
Someone asked by email:
After building an SD card image and boot-up the Arria10 & AD9371 system there are issues with IIO Oscilloscope. Here are the stats below:
QSYS 17.0 Project:   AD9371 Arria10 Project (\hdl\projects\adrv9371x\a10soc) - ADI HDL Repo tag: hdl_2017_r1
Altera-Linux Branch: https://github.com/analogdevicesinc/linux/tree/altera_4.9
Device Tree:  socfpga_arria10_socdk_adrv9371.dts I am taking this directly and not modifying it or adding any additional device-tree content.
https://github.com/analogdevicesinc/linux/blob/altera_4.9/arch/arm/boot/dts/socfpga_arria10_socdk_adrv9371.dts
IIO Oscilloscope version:  Library version: 0.9 (git tag: 90075e6)
When opening up IIO-Scope it takes a long time to connect. During this time I see error messages show up:
[  993.187069] ERROR: 40: Invalid ObsRx channel in setObsRxManualGain().
[ 1489.054760] ERROR: 40: Invalid ObsRx channel in setObsRxManualGain().
All the devices appear correctly in the Rx scopes.
But when trying to view data I get the following error
New client connected from 0.0.0.0
ERROR: Reading from device failed: -110
I can interact with the UI and see values change (ie: hardware gain and RSSI updates), I have not thoroughly gone through every parameter however.
I’ve attached an iio_info and a dmesg log. I did not see anything too glaring in there. IIO_INFO does report a few error messages but I’m not sure what they indicate or if they’re benign
IIO Info:
9 device-specific attributes found:
                attr  0: calibrate_tx_lol_ext_en value: 0
                attr  1: calibrate_rx_qec_en value: 0
                attr  2: gain_table_config ERROR: Permission denied (-13)
                attr  3: ensm_mode_available value: radio_on radio_off
                attr  4: calibrate ERROR: Input/output error (-5)
    2 debug attributes found:
                debug attr  0: pseudorandom_err_check value: CH0 : PN9 : Out of Sync : PN Error
CH1 : PN9 : Out of Sync : PN Error
CH2 : PN9 : Out of Sync : PN Error
CH3 : PN9 : Out of Sync : PN Error
Help/guidance would be appreciated.
