AD9910 , How can load data and playback it using Arduino Uno
Question asked by mohamed.sayed on Apr 9, 2018
Latest reply on May 3, 2018 by mcee
HI everybody....
I try to operate ram mode  mode without evaluation board but i failed.i tried  by SPI protocol using Arduino uno "micro-controller" to Operate RAM mode.
 -Fsystemclk = 1GHz
 - Start frequency = 250 MHz...............................0000000000..............10 bits
 - End frequency = 350 MHz................................11 11101000..............10 bits
 - frequency step = 0.1 MHz
 -rate =40ns.........................................................0000 0000 0000 1010..............16 bits
my program in steps :
1- CFR1......... {0x80,0x00,0x00,0x00} ram enable=1   to make the profile0 to be Ram-profile not single tone-profile
2-CFR2.........default {0x00,0x40,0x08,0x20}
3-CFR3........ {0x1D,0x3f,0x41,0x32}......1GSbps
4-RAM Profile registers.........{0x00,0x00,0x0a,0xfa,0x00,0x00,0x00,0x21} Write the desired start ,end and rate                                                               addresses like above adresses from 250MHz to 350MHz (0000000000 to 11 1110                                                              1000) and the rate (0000 0000 0000 1010).
5-MASTREST
6-CS.....LOW
7- write the CFR1 data from the arduino to the ad9910
8-Apply the profile pins to select the Ram-profile0........digitalWrite(prof0,LOW);
        digitalWrite(prof1,LOW);
        digitalWrite(prof2,LOW);
9-write the Ram-profile0 data from the arduino to the ad9910
10-update
11- write the CFR2 data from the arduino to the ad9910
12-update
13-write the CFR3 data from the arduino to the ad9910
14-update
15-CFR1......ram enable=0 to Write the data to the 0x16 RAM
16-update
17- Write the data to the 0x16 Ram like this.............tx_byte(0x16);
        for(f=0;f<1000;f++)
        value = (unsigned long)(round((x*pow(2,32))/1000));....FTW eq.
        x=x+0.1;........x=250MHz +0.1 Step
        tx_byte(value);......take first byte & transfer it
        tx_byte(value>>8);......take second byte & transfer it
        tx_byte(value>>16);......take third  byte & transfer it
        tx_byte(value>>24);......take the fourth  byte & transfer it
18-update
19- CFR1......ram enable=1 to Operate the play-back mode
20-update
21-CS.....HIGH
////////////////////////////////////////////////////////////////////////////CODE/////////////////////////////////////////////////////////////////////////////////////////
#define prof0 0
#define prof1 1
#define prof2 2
#define MASTREST 5
#define upd 6
#define CS 10
#include <SPI.h>
unsigned char cfr1[]={0x80,0x00,0x00,0x00};                       //Step_1
unsigned char cfr2[]={0x00,0x40,0x08,0x20};                       //Step_2
unsigned char cfr3[]={0x1D,0x3f,0x41,0x32};                        //Step_3
unsigned char profile0ram[]={0x00,0x00,0x0a,0xfa,0x00,0x00,0x00,0x21};                     //Step_4
void setup()
unsigned int k,m,f;
unsigned long value;
float x=250;
SPI.begin();
pinMode(MASTREST,OUTPUT);
pinMode(upd,OUTPUT);
pinMode(CS,OUTPUT);
pinMode(prof0,OUTPUT);
pinMode(prof1,OUTPUT);
pinMode(prof2,OUTPUT);
digitalWrite(MASTREST,HIGH);                                                             //Step_5
digitalWrite(MASTREST,LOW);
digitalWrite(CS,LOW);        //Step_6
tx_byte(0x00);        //Step_7
for(m=0;m<4;m++)
tx_byte(cfr1[m]);
digitalWrite(prof0,LOW);        //Step_8
tx_byte(0x0e);        //Step_9
for(m=0;m<8;m++)
tx_byte(profile0ram[m]);
digitalWrite(upd,HIGH);        //Step_10
digitalWrite(upd,LOW);
tx_byte(0x01);        //Step_11
for(m=0;m<4;m++)
tx_byte(cfr2[m]);
digitalWrite(upd,HIGH);        //Step_12
tx_byte(0x02);        //Step_13
for(m=0;m<4;m++)
tx_byte(cfr3[m]);
digitalWrite(upd,HIGH);        //Step_14
cfr1[m]=0x00;        //Step_15
tx_byte(0x00);
for(m=0;m<4;m++)
tx_byte(cfr1[m]);
digitalWrite(upd,HIGH);        //Step_16
tx_byte(0x16);        //Step_17
for(f=0;f<1000;f++)
x=x+0.1;
tx_byte(value);
tx_byte(value>>8);
tx_byte(value>>16);
tx_byte(value>>24);
digitalWrite(upd,HIGH);        //Step_18
cfr1[m]=0x80;        //Step_19
tx_byte(0x00);
for(m=0;m<4;m++)
tx_byte(cfr1[m]);
digitalWrite(upd,HIGH);        //Step_20
digitalWrite(CS,HIGH);        //Step_21
void tx_byte(unsigned char tx_dat)                                      // Function for transfer data from Arduino to AD9910
SPI.transfer(tx_dat);
void loop()
Please ,can you help me in my project.....thank you ^_^
