strcpy volatile char * not accepted as argument
Question asked by dfrisch on Dec 8, 2011
Latest reply on Dec 15, 2011 by dfrisch
Hello, My name is Dustin and I am currently attending the University of Calgary and taking ENCM511 with Dr. Mike Smith.
I have found what appears to be a bug in the VisualDSP++ compiler I figured
I should post this in case this was not the expected operation of the compiler,
otherwise it should help someone else who has the problem in the future
Here is the code to show the problem:
#include <string.h>
volatile char thing[42];
void main(void) {
    strcpy(thing, "This should compile - ENCM511 rules");
    strcpy( (char *) thing, "This does compile - ENCM511 rules");
Here is the output from the build window:
.\Lab4Tests_main.cpp
".\Lab4Tests_main.cpp", line 6: cc0167:  error: argument of type
          "volatile char *" is incompatible with parameter of type "char *"
  strcpy(thing, "This should compile -- ENCM511 rules");
1 error detected in the compilation of ".\Lab4Tests_main.cpp".
cc3089: fatal error: Compilation failed
Tool failed with exit/exception code: 1.
Build was unsuccessful.
