ADXL372 weird Y and Z initial readings
Question asked by dla1996 on Mar 27, 2018
Latest reply on Mar 28, 2018 by jwang
Hi I am getting weird readings from my ADXL372 evaluation board.
I am using it in I2C.
I initialize my board by reseting it first and then perform these I2C communications:
In power control register I send 0x0F to Enable I2C highspeed, Low Pass, High pass and full bandwidth measurement mode.
In the High-pass filter settings register I send 0x01 to enable the high pass filter corner 1.
In the Measurement control register I send 0x44 to enable AUTOSLEEP and LOW_NOISE.
When I am reading the X, Y, Z registers with the board laying flat I get values like these:
All readings were taken 5 seconds apart so there are some variations. I tried to keep them as steady as possible as I don't have an actual lab to test it.
FLAT facing up:
X: 00 E0    Y: FF 50   Z: FE 00
X: 00 D0    Y: FF 40   Z: FE 60
X: 00 50     Y: FF 90   Z: FE 30
X = 1G: as close as I can
X: 01 70    Y: FF 60   Z: FD 40
X: 01 50    Y: FF 30   Z: FD 70
X: 01 A0    Y: FF 50   Z: FD 80
X = -1G:
X: FF C0   Y: FF B0   Z: FD A0
X: 00 20    Y: FF 50   Z: FD 60
X: 00 20    Y: FF 40   Z: FD 50
Y = 1G:
X: 00 B0    Y: 00 10   Z: FD D0
X: 00 B0    Y: 00 30   Z: FD B0
X: 00 D0    Y: FF D0  Z: FD 90
Y = -1G:
X: 00 D0   Y: FE B0   Z: FD 70
X: 00 B0    Y: FF 10   Z: FD 70
X: 00 E0    Y: FE A0   Z: FD 70
I thought my problem was that they were in twos complement so I passed my data into a function to perform twos complement if the highest bit was 1 and then I get these values which, hindsight doesn't seem like a good thing to do to check if my data is correct:
FLAT facing up:
X: 00 09    Y: 00 0A   Z: 00 1E
X: 00 0C    Y: 00 0A   Z: 00 1D
X: 00 0B     Y: 00 0E   Z: 00 21
X: 00 15    Y: 00 0B   Z: 00 27
X: 00 15    Y: 00 09   Z: 00 29
X: 00 14     Y: 00 09   Z: 00 29
X = -1G:
X: 00 01    Y: 00 08   Z: 00 29
X: 00 01    Y: 00 0A   Z: 00 26
X: 00 05     Y: 00 0A   Z: 00 2B
Y = 1G:
X: 00 0E    Y: 00 03   Z: 00 27
X: 00 0D    Y: 00 05   Z: 00 25
X: 00 0D    Y: 00 01   Z: 00 25
Y = -1G:
X: 00 09    Y: 00 16   Z: 00 2B
X: 00 0B    Y: 00 11   Z: 00 29
X: 00 0B    Y: 00 16   Z: 00 26
I don't know why my Y and Z Data start out at negative values even though the board is on a flat surface. Also, does my data look correct?
