AD5380 Evaluation Board
Question asked by eric_gebionics on Mar 22, 2018
Latest reply on Mar 28, 2018 by rrosario
Does anybody know how to connect to the J4 on the DAC evaluation board EVAL-AD5380SDZ ? J4 is a straight SMB jack. I believe it is a female one and I need male cable ? I need to provide a external reference voltage to the board.
Also, does anyone know the exact timing diagram to read/write the Control Registers (CR) ? The timing diagram on the datasheet is good enough to write/read the 40 channels, but I can't use the same timing diagram to read/write the CR since in the later case, the WR pin is used to indicate read/write operation. I am using the parallel interface.
Thank you.
Eric
