AD7511 Application Note Question (AN1270) for FPGA HDMI Output
Question asked by workingdoc on Mar 15, 2018
Latest reply on May 22, 2018 by workingdoc
I am following directions for Application note AN-1270 for getting up and running with the ADV7511 chip.  I have attached this document.
I have setup the Verilog Code.  It was not working the way it was documented, but after troubleshooting each function to get the desired waveform, it seems to work OK.
I am using Zilinx ZC702 FPGA board.
My question is this:  the HDMI is not working though timing looks like it should be sending signal.  In the AN, List 4 Script, there is some code I do not understand at all how to implement.  Would this explain why the HDMI is not working despite having signal connected to correct pins on FPGA pinouts?
I read couple things on I2C but not sure how to implement these comments or what the script is telling the chip to do.
I would really appreciate some guidance here, as I am just getting into FPGA embedded development.
