About AD1955 SPI setting and I2S signal frequency.
Question asked by homeway on Mar 12, 2018
Latest reply on Mar 15, 2018 by homeway
Hi ADI,
I have many questions about AD1955.
-----------------SPI control setting---------------
I want to use 24.576 MHz as MCLK, and  play sample rate 192 kHz or 96 kHz PCM audio.
According to https://ez.analog.com/thread/18961#90158
I think SPI register should be set as below:
[Register  0]
15--0 Operation
14--0 Not Muted
13:12--00 PCM
11:10--00 Stereo
9:8--10 (for 192KHz) / 01 (for 96kHz)
7:6--00 None
5:4--00 I2S
3:2--00 24bits
1:0--00 Register 0
[Register 1]
10:9-- 01 512 x fs (48 kHz*512= 24.576 MHz)
1:0-- 01 Register 1
Q1. Does [Register 0 9:8] set the interpolation mode?
If yes, when I setting [Register 0 10:9] 192 kHz, why don't I need to change MCLK Mode [Register 1 10:9] setting for different fs?
PCM mode
Q2. What value should I setting for residual bits of register 1?
---------------I2S signal frequency-----------------
If I want to play 192 kHz / 24 bits audio,
MCLK= sample rate * bits * channel# = 192k * (24+8) * 2 = 12.288 MHz
LRCK= 192 kHz
BCLK= 12.288 MHz.
Q3. The MCLK frequency which I used for AD1955 should be multiplier for 12.288MHz, is it right?
Q4.  What is the meaning for 8 bits?
Q5. If I use 24.576 MHz as MCLK, can I use 24.576 MHz for BCLK?
Please help me to figure out these questions, thanks a lot.
B.R.
Homeway
