question on analog multiplexer/demultiplexer without using digital switching function
Question asked by pacirf on Mar 11, 2018
Latest reply on Aug 8, 2018 by Davidforde
Dear Mento,
I am a beginner amateur about analog multiplexer
and will try to use for the application of analog multiplexer/demultiplexer without using digital switching function.
I am going to input 12 signals through 12 input pins at 800 MHz as central frequency
and make the 12 input signals entered through the above 12 [input] pins output through one single [output] pin.
The signals output through this one single [output] pin should include the above 12 input signals.
That is, I will not select one single signal between 12 input signals.
Therefore, I will not use digital switching function correspondent to selection of only one single signal.
Shortly, I need all of 12 signals through [output] pin.
 Meanwhile, I need analog demultiplexer available for outputting above 12 signals through 12 [output] pins
since receiving above 12 signals through one single [input] pin.
In the case of analog multiplexer/demultiplexer, How much positive voltage must I supply to [Enable] pin ?
and what part or passive element must I connect to the pins of [S0], [S1], [S2] ?
Could you recommend some of the proper analog multiplexers/demultiplexers of ANALOG DEVICES
satisfying my application ?
And could you design the circuit / element / power supply etc, connection relation to each pin of
the analog multiplexer/demultiplexer you recommend, please ?
Thank you
With Best Regards,
Yoon
