How do I expose the AXI bus via a UIO device?
Question asked by charleswr on Mar 6, 2018
Latest reply on Mar 6, 2018 by DragosB
I am trying to use the user-space platform driver to the AD 9361 provided in https://github.com/analogdevicesinc/no-OS
I am able to initialize spidev32766.0, but I can’t get any uio devices to be displayed in /dev/.
I have tried adding uio entries to the device tree but am still new to modifying devicetree and not am not  really sure what exactly needs to be done.
How do I expos the AXI bus at 0x43C00000 as uio devices? Is there a driver that i'm missing?
I am running Linux 4.9.0 as provided by https://github.com/analogdevicesinc/linux 2017_R1 and running on a zynq-7000 chip.
axi ad9361 linux
Here is my current device tree:
/dts-v1/;
                compatible = "xlnx,zynq-7000";
                #address-cells = <0x1>;
                #size-cells = <0x1>;
                interrupt-parent = <0x1>;
                model = "ags,FMC";
                aliases {
                                ethernet0 = "/amba@0/eth@e000b000";
                                serial0 = "/amba@0/uart@e0001000";
                cpus {
                                #size-cells = <0x0>;
                                cpu@0 {
                                                bus-handle = <0x2>;
                                                clock-latency = <0x3e8>;
                                                clocks = <0x3 0x3>;
                                                compatible = "arm,cortex-a9";
                                                device_type = "cpu";
                                                interrupt-handle = <0x1>;
                                                operating-points = <0xa2c2b 0xf4240 0x51616 0xf4240 0x3640f 0xf4240>;
                                                reg = <0x0>;
                                cpu@1 {
                                                bus-handle = <0x2>;
                                                clocks = <0x3 0x3>;
                                                reg = <0x1>;
                pmu {
                                compatible = "arm,cortex-a9-pmu";
                                interrupts = <0x0 0x5 0x4 0x0 0x6 0x4>;
                                reg = <0xf8891000 0x1000 0xf8893000 0x1000>;
                                reg-names = "cpu0", "cpu1";
                amba@0 {
                                compatible = "simple-bus";
                                ranges;
                                linux,phandle = <0x2>;
                                phandle = <0x2>;
                                intc@f8f01000 {
                                                interrupt-controller;
                                                compatible = "arm,cortex-a9-gic";
                                                #interrupt-cells = <0x3>;
                                                reg = <0xf8f01000 0x1000 0xf8f00100 0x100>;
                                                linux,phandle = <0x1>;
                                                phandle = <0x1>;
                                pl310@f8f02000 {
                                                compatible = "arm,pl310-cache";
                                                cache-unified;
                                                cache-level = <0x2>;
                                                reg = <0xf8f02000 0x1000>;
                                                arm,data-latency = <0x3 0x2 0x2>;
                                                arm,tag-latency = <0x2 0x2 0x2>;
                                uart@e0001000 {
                                                compatible = "xlnx,xuartps", "cdns,uart-r1p8";
                                                clocks = <0x3 0x18 0x3 0x29>;
                                                clock-names = "uart_clk", "pclk";
                                                reg = <0xe0001000 0x1000>;
                                                interrupts = <0x0 0x32 0x4>;
                                                port-number = <0x0>;
                                                current-speed = <0x1c200>;
                                                device_type = "serial";
                                ps7-dma@f8003000 {
                                                #dma-cells = <0x1>;
                                                #dma-channels = <0x8>;
                                                #dma-requests = <0x4>;
                                                compatible = "arm,primecell", "arm,pl330";
                                                interrupts = <0x0 0xd 0x4 0x0 0xe 0x4 0x0 0xf 0x4 0x0 0x10 0x4 0x0 0x11 0x4 0x0 0x28 0x4 0x0 0x29 0x4 0x0 0x2a 0x4 0x0 0x2b 0x4>;
                                                reg = <0xf8003000 0x1000>;
                                                clocks = <0x3 0x1b>;
                                                clock-names = "apb_pclk";
                                                linux,phandle = <0x11>;
                                                phandle = <0x11>;
                                slcr@f8000000 {
                                                compatible = "xlnx,zynq-slcr", "syscon";
                                                reg = <0xf8000000 0x1000>;
                                                ranges;
                                                clkc {
        #clock-cells = <0x1>;
        clock-output-names = "armpll", "ddrpll", "iopll", "cpu_6or4x", "cpu_3or2x", "cpu_2x", "cpu_1x", "ddr2x", "ddr3x", "dci", "lqspi", "smc", "pcap", "gem0", "gem1", "fclk0", "fclk1", "fclk2", "fclk3", "can0", "can1", "sdio0", "sdio1", "uart0", "uart1", "spi0", "spi1", "dma", "usb0_aper", "usb1_aper", "gem0_aper", "gem1_aper", "sdio0_aper", "sdio1_aper", "spi0_aper", "spi1_aper", "can0_aper", "can1_aper", "i2c0_aper", "i2c1_aper", "uart0_aper", "uart1_aper", "gpio_aper", "lqspi_aper", "smc_aper", "swdt", "dbg_trc", "dbg_apb";
        compatible = "xlnx,ps7-clkc";
        ps-clk-frequency = <0x1fca055>;
        fclk-enable = <0xf>;
        reg = <0x100 0x100>;
        linux,phandle = <0x3>;
        phandle = <0x3>;
                                timer@0xf8001000 {
                                                compatible = "cdns,ttc";
                                                reg = <0xf8001000 0x1000>;
                                                interrupts = <0x0 0xa 0x4 0x0 0xb 0x4 0x0 0xc 0x4>;
                                                clocks = <0x3 0x6>;
                                timer@f8f00600 {
                                                compatible = "arm,cortex-a9-twd-timer";
                                                reg = <0xf8f00600 0x20>;
                                                interrupts = <0x1 0xd 0x301>;
                                                clocks = <0x3 0x4>;
                                swdt@f8005000 {
                                                device_type = "watchdog";
                                                compatible = "xlnx,ps7-wdt-1.00.a", "xlnx,zynq-wdt-1.00.a";
                                                reg = <0xf8005000 0x100>;
                                                interrupts = <0x0 0x9 0x4>;
                                                clocks = <0x3 0x2d>;
                                                reset = <0x0>;
                                                timeout = <0xa>;
                                scuwdt@f8f00620 {
                                                compatible = "arm,mpcore_wdt";
                                                reg = <0xf8f00620 0x20>;
                                                clocks = <0x3 0x4>;
                                                reset = <0x1>;
                                eth@e000b000 {
                                                compatible = "xlnx,ps7-ethernet-1.00.a";
                                                reg = <0xe000b000 0x1000>;
                                                interrupts = <0x0 0x16 0x4>;
                                                clock-names = "ref_clk", "aper_clk";
                                                clocks = <0x3 0xd 0x3 0x1e>;
                                                xlnx,enet-clk-freq-hz = <0x17d7840>;
                                                xlnx,enet-reset = "MIO 11";
                                                xlnx,enet-slcr-1000mbps-div0 = <0x8>;
                                                xlnx,enet-slcr-1000mbps-div1 = <0x1>;
                                                xlnx,enet-slcr-100mbps-div0 = <0x8>;
                                                xlnx,enet-slcr-100mbps-div1 = <0x5>;
                                                xlnx,enet-slcr-10mbps-div0 = <0x8>;
                                                xlnx,enet-slcr-10mbps-div1 = <0x32>;
                                                xlnx,eth-mode = <0x1>;
                                                xlnx,has-mdio = <0x1>;
                                                xlnx,ptp-enet-clock = <0x69f6bcb>;
                                                phy-handle = <0x4>;
                                                phy-mode = "rgmii-id";
                                                phy@0 {
        compatible = "marvell,88e1510";
        device_type = "ethernet-phy";
        reg = <0x0>;
        marvell,reg-init = <0x3 0x10 0xff00 0x1e 0x3 0x11 0xfff0 0x0>;
        linux,phandle = <0x4>;
        phandle = <0x4>;
                                gpio@e000a000 {
                                                compatible = "xlnx,ps7-gpio-1.00.a", "xlnx,zynq-gpio-1.00.a", "xlnx,zynq-gpio-1.0";
                                                reg = <0xe000a000 0x1000>;
                                                interrupts = <0x0 0x14 0x4>;
                                                clocks = <0x3 0x2a>;
                                                gpio-controller;
                                                #gpio-cells = <0x2>;
                                                #interrupt-cells = <0x2>;
                                                linux,phandle = <0x5>;
                                                phandle = <0x5>;
                                sdhci@e0100000 {
                                                compatible = "xlnx,ps7-sdio-1.00.a", "arasan,sdhci-8.9a";
                                                reg = <0xe0100000 0x1000>;
                                                interrupts = <0x0 0x18 0x4>;
                                                clock-names = "clk_xin", "clk_ahb";
                                                clocks = <0x3 0x15 0x3 0x20>;
                                                xlnx,has-cd = <0x1>;
                                                clock-frequency = <0x2faf080>;
                                                status = "okay";
                                                disable-wp;
                                i2c@e0004000 {
                                                compatible = "cdns,i2c-r1p10";
                                                clocks = <0x3 0x26>;
                                                interrupts = <0x0 0x19 0x4>;
                                                reg = <0xe0004000 0x1000>;
                                                clock-frequency = <0x61a80>;
                                spi@e0006000 {
                                                compatible = "cdns,spi-r1p6", "xlnx,zynq-spi-1.00.a", "xlnx,ps7-spi-1.00.a";
                                                interrupts = <0x0 0x1a 0x4>;
                                                clock-names = "ref_clk", "aper_clk", "pclk";
                                                clocks = <0x3 0x19 0x3 0x22 0x3 0x22>;
                                                num-chip-select = <0x4>;
                                                reg = <0xe0006000 0x1000>;
                                                speed-hz = <0x5f5e100>;
                                                status = "okay";
                                                spidev@0 {
        compatible = "spidev";
        reg = <0x00000000>;
        spi-max-frequency = <0x017d7840>;
                                spi@e0007000 {
                                                interrupts = <0x0 0x31 0x4>;
                                                clocks = <0x3 0x1a 0x3 0x23 0x3 0x23>;
                                                num-chip-select = <0x3>;
                                                is-decoded-cs = <0x0>;
                                                reg = <0xe0007000 0x1000>;
                                                speed-hz = <0x1e8480>;
                                                spidev@0 {
        reg = <0x0>;
        spi-max-frequency = <0x1e8480>;
                                                spidev@1 {
        reg = <0x1>;
                                                spidev@2 {
        reg = <0x2>;
                                devcfg@f8007000 {
                                                compatible = "xlnx,zynq-devcfg-1.0";
                                                reg = <0xf8007000 0x100>;
                                                interrupts = <0x0 0x8 0x4>;
                                                clocks = <0x3 0xc 0x3 0xf 0x3 0x10 0x3 0x11 0x3 0x12>;
                                                clock-names = "ref_clk", "fclk0", "fclk1", "fclk2", "fclk3";
                efuse: efuse@f800d000 {
                        compatible = "xlnx,zynq-efuse";
                        reg = <0xf800d000 0x20>;
                                xadc@f8007100 {
                                                compatible = "xlnx,zynq-xadc-1.00.a", "xlnx,ps7-xadc-1.00.a";
                                                reg = <0xf8007100 0x20>;
                                                interrupts = <0x0 0x7 0x4>;
                                                clocks = <0x3 0xc>;
                                ps7-ddrc@f8006000 {
                                                compatible = "xlnx,zynq-ddrc-a05", "xlnx,ps7-ddrc-1.00.a", "xlnx,ps7-ddrc", "xlnx,zynq-ddrc-1.0";
                                                reg = <0xf8006000 0x1000>;
                                                xlnx,has-ecc = <0x0>;
                                ps7-ocm@f800c000 {
                                                compatible = "xlnx,ps7-ocmc-1.00.a", "xlnx,zynq-ocmc-1.0";
                                                interrupts = <0x0 0x3 0x4>;
                                                reg = <0xf800c000 0x1000>;
                memory {
                                device_type = "memory";
                                reg = <0x0 0x40000000>;
                chosen {
                                linux,stdout-path = "/amba@0/uart@E0001000";
                clocks {
                                clock@0 {
                                                #clock-cells = <0x0>;
                                                compatible = "fixed-clock";
                                                clock-frequency = <0x2625a00>;
                                                clock-output-names = "ad9361_ext_refclk";
                                                linux,phandle = <0x6>;
                                                phandle = <0x6>;
                                clock@1 {
                                                clock-frequency = <0x16e3600>;
                                                clock-output-names = "24MHz";
                                                linux,phandle = <0x8>;
                                                phandle = <0x8>;
                                clock@2 {
                                                compatible = "gpio-gate-clock";
                                                clocks = <0x8>;
                                                enable-gpios = <0x5 0x9 0x1>;
                                clock@3 {
                                                clock-frequency = <0x17d7840>;
                                                clock-output-names = "ad9517_refclk";
                                                linux,phandle = <0x7>;
                                                phandle = <0x7>;
                fpga-axi@0 {
                                ranges;
                                dma@7c400000 {
                                                compatible = "adi,axi-dmac-1.00.a";
                                                reg = <0x7c400000 0x10000>;
                                                #dma-cells = <0x1>;
                                                interrupts = <0x0 0x39 0x0>;
                                                clocks = <0x3 0x10>;
                                                linux,phandle = <0x9>;
                                                phandle = <0x9>;
                                                dma-channel {
        adi,source-bus-width = <0x40>;
        adi,destination-bus-width = <0x40>;
        adi,type = <0x0>;
                                dma@7c420000 {
                                                reg = <0x7c420000 0x10000>;
                                                #dma-cells = <0x1>;
                                                interrupts = <0x0 0x38 0x0>;
                                                linux,phandle = <0xb>;
                                                phandle = <0xb>;
                                                dma-channel {
        adi,type = <0x1>;
        adi,cyclic;
                                cf-ad9361-lpc@79020000 {
                                                compatible = "adi,axi-ad9361-6.00.a";
                                                reg = <0x79020000 0x6000>;
                                                dmas = <0x9 0x0>;
                                                dma-names = "rx";
                                                spibus-connected = <0xa>;
                                cf-ad9361-dds-core-lpc@79024000 {
                                                compatible = "adi,axi-ad9361-dds-6.00.a";
                                                reg = <0x79024000 0x1000>;
                                                clocks = <0xa 0xd>;
                                                clock-names = "sampl_clk";
                                                dmas = <0xb 0x0>;
                                                dma-names = "tx";
                                efuse@f800d000 {
                                                compatable = "xlnx,zynq-efuse";
And my current uEnv.txt:
slcr_unlock_cmd=mw.l 0xF8000008 0xDF0D
slcr_lock_cmd=mw.l 0xF8000004 0x767B
fpga_set_cmd=echo SettingClocks && run slcr_unlock_cmd && mw.l 0xF8000170 0x00100A00 && mw.l 0xF8000180 0x00100500 && mw.l 0xF8000190 0x00100E00 && mw.l 0xF80001A0 0x00101A20 &&  run slcr_lock_cmd
uenvcmd=run adi_sdboot
adi_sdboot=run fpga_set_cmd && echo Copying Linux from SD to RAM... && fatload mmc 0 0x3000000 ${kernel_image} && fatload mmc 0 0x2A00000 ${devicetree_image} && if fatload mmc 0 0x2000000 ${ramdisk_image}; then bootm 0x3000000 0x2000000 0x2A00000; else bootm 0x3000000 - 0x2A00000; fi
bootargs=console=ttyPS0,115200 root=/dev/mmcblk0p2 rw earlyprintk rootfstype=ext4 rootwait
