charlie.paterlini@gmail.com
Oscillators stops running without any warning
Discussion created by charlie.paterlini@gmail.com on Mar 6, 2018
Latest reply on Mar 10, 2018 by charlie.paterlini@gmail.com
Hi, needing to output an hardware flashing led , I thought to use the output square wave block. It works perfectly. But, after designing more functions  using other bloks modules, the square wave block stops working. Also using other blocks like timers to simulate the same effect, have no success. No full memory errors nor something like that. It seems that bloks requiring a simple delay or count, don't works anymore or no more room in memory .
There's an easy way to see a detailed compiled file with error warning?
If I show Output , after compiling, the frame remain blank. Why?
Sigmastudio 1.16 beta (also 1.15 has the same issue).
ADAU1701. Freedsp Board.
Charlie.
