ada4950-1 vocm problem?
Question asked by azita on Mar 3, 2018
Latest reply on Mar 16, 2018 by azita
i want to use ada4950-1 as an single to differential amplifier with the gain of 1 and output common voltage  at  500mv , i used adr130 to produce the 500mv and connected directly its output to the vocm of ada4950.when i power up the board and just  measure the voltage at the differential outputs , i see the dc voltage at output positive terminal is 493 mv and output  negative terminal is 505mv . it means there is problem . why i see this problem ?is there any way that we can see identical voltage at the output?best regards
