adv7612 edid
Question asked by tom on Feb 25, 2018
Latest reply on Mar 1, 2018 by tom
hello, i set the register as below
   PSIIC0_Write(0x98, 0xFF, 0x1, 0x80); //I2C Reset
    PSIIC0_Write(0x98, 0xF4, 0x1, 0x80); //Config CEC slave address
    PSIIC0_Write(0x98, 0xF5, 0x1, 0x7C); //Config INFOFRAME slave address
    PSIIC0_Write(0x98, 0xF8, 0x1, 0x4C); //Config DPLL slave address
    PSIIC0_Write(0x98, 0xF9, 0x1, 0x64); //Config KSV slave address
    PSIIC0_Write(0x98, 0xFA, 0x1, 0x6C); //Config EDID slave address
    PSIIC0_Write(0x98, 0xFB, 0x1, 0x68); //Config HDMI slave address
    PSIIC0_Write(0x98, 0xFD, 0x1, 0x44); //Config CP slave address
    PSIIC0_Write(0x98, 0x01, 0x1, 0x06); //Prim_mode = 110b HDI-GR
    PSIIC0_Write(0x98, 0x02, 0x1, 0xF2); //Auto CSC, RGB out, Set RGB full grade 0-255 ,change
    PSIIC0_Write(0x98, 0x03, 0x1, 0x40); //24 bit SDR 444 Mode 0
    PSIIC0_Write(0x98, 0x05, 0x1, 0x28); //AV Codes Off
    PSIIC0_Write(0x98, 0x06, 0x1, 0xA6); //Invert on VS,HS pins
    PSIIC0_Write(0x98, 0x0B, 0x1, 0x44); //Power up part
    PSIIC0_Write(0x98, 0x0C, 0x1, 0x42); //Power up part
    PSIIC0_Write(0x98, 0x14, 0x1, 0x7F); //Max Drive Strength
    PSIIC0_Write(0x98, 0x15, 0x1, 0x80); //Disable Tristate of Pins
    PSIIC0_Write(0x98, 0x19, 0x1, 0x80); //LLC DLL phase(0-31,set 0)
    PSIIC0_Write(0x98, 0x33, 0x1, 0x40); //LLD DLL MUX enable
    PSIIC0_Write(0x44, 0xBA, 0x1, 0x01); //Set HDMI freerun
    PSIIC0_Write(0x64, 0x40, 0x1, 0x81); //Disable HDCP 1.1 features
    PSIIC0_Write(0x68, 0x9B, 0x1, 0x03); // ADI recommended setting
   PSIIC0_Write(0x68, 0x00, 0x1, 0x08); //Set HDMI Input Port A (BG_MEAS_PORT_SEL = 001b)
    PSIIC0_Write(0x68, 0x02, 0x1, 0x03); //Enable Ports A & B in background mode
    PSIIC0_Write(0x68, 0x83, 0x1, 0xFC); //Enable clock terminators for port A & B
    PSIIC0_Write(0x68, 0x6F, 0x1, 0x0C); //ADI recommended setting
    PSIIC0_Write(0x68, 0x85, 0x1, 0x1F); //ADI recommended setting
    PSIIC0_Write(0x68, 0x87, 0x1, 0x70); //ADI recommended setting
    PSIIC0_Write(0x68, 0x8D, 0x1, 0x04); //LFG Port A
    PSIIC0_Write(0x68, 0x8E, 0x1, 0x1E); //HFG Port A
    PSIIC0_Write(0x68, 0x1A, 0x1, 0x8A); //unmute audio
    PSIIC0_Write(0x68, 0x57, 0x1, 0xDA); //ADI recommended setting
    PSIIC0_Write(0x68, 0x58, 0x1, 0x01); //ADI recommended setting
    PSIIC0_Write(0x68, 0x03, 0x1, 0x98); //DIS_I2C_ZERO_COMPR
    PSIIC0_Write(0x68, 0x75, 0x1, 0x10); //DDC drive strength
    PSIIC0_Write(0x68, 0x90, 0x1, 0x04); //LFG Port B
    PSIIC0_Write(0x68, 0x91, 0x1, 0x1E); //HFG Port B
//configure EDID
    //Manual Hot Plug Detect
    PSIIC0_Write(0x68, 0x6C, 0x1, 0xA1);
    //Deassert HPD
    PSIIC0_Write(0x98, 0x20, 0x1, 0x30);
    //Enable internal EDID ram
    PSIIC0_Write(0x64, 0x74, 0x1, 0x03);
    //Initial edid
    Init_Edid();
    delay_nms(20);
    //Assert HPD
    PSIIC0_Write(0x98, 0x20, 0x1, 0xf0);// Assert HPD of port A
but   when the ddc i2c read the edid ,  the adv 7612  return  NACK.
what's the problem?
