not able to detect linear motion of the device using adxl335 accelerometer
Question asked by softlab on Nov 29, 2011
Latest reply on Mar 15, 2012 by Kevin.G
Dear All,
I can able to read the ADXL accelerometer readings (X, Y and Z outputs) from PIC16LF1827 MCU and able to detect if the device is tilted or vibrated. But not able to detect if the device moved horizontally or verically. I have placed ADXL inside the device.
0.1uF ceramic capacitors used as decoupling and also on X, Y and Z outputs as filter capacitors. I have directly connected the ADXL (X, Y and Z axis) outputs to PIC MCU. No voltage-follower has been used between PIC and Sensor.
Steps:
1. Read the ADXL (X, Y and Z) outputs and store it in to variables initial_X, initial_Y and initial_Z using ADC, when device is activated.
2. wait for few seconds (say, for example, 5 seconds, it may be increased in future based on user requirements)
3. Read ADXL outputs and store the values in to variables Final_X, Final_Y and Final_Z  and compare with initial_X, initial_Y and initial_Z continuously
4. If desired difference found on ADXL output (Final_X - initial_X or Final_Y -  initial_Y or Final_Z -  initial_Z) lit the LED
The code is as follows:
IDE : MPLAB v8.63
Compiler : Hi-Tech C v9.83
// Declare variables to store ADXL outputs
unsigned int val_X_Initial; //ADC Value
unsigned int val_Y_Initial; //ADC Value
unsigned int val_Z_Initial; //ADC Value
unsigned int val_X_Final; //ADC Value
unsigned int val_Y_Final; //ADC Value
unsigned int val_Z_Final; //ADC Value
Step 1:
// READ ADC Initial values
val_X_Initial = read_ADC(0);   //Read Channel 0 (AN0/RA0)
val_Y_Initial = read_ADC(1);   //Read Channel 1 (AN1/RA1)
val_Z_Initial = read_ADC(2);   //Read Channel 2 (AN2/RA2)
Step 2:
// wait 5 seconds
__delay_ms(5000);
Step 3:
//Read ADXL outputs and store the values in to variables Final_X, Final_Y and Final_Z  and compare with initial_X, initial_Y and initial_Z continuously
while (1){
val_X_Final = read_ADC(0);   //Read Channel 0 (AN0/RA0)
val_Y_Final = read_ADC(1);   //Read Channel 1 (AN1/RA1)
val_Z_Final = read_ADC(2);   //Read Channel 2 (AN2/RA2)
Step 4:
//If desired difference found on ADXL output (Final_X - initial_X or Final_Y -  initial_Y or Final_Z -  initial_Z) lit the LED
if ((val_X_Final < (val_X_Initial - 15))|| (val_X_Final > (val_X_Initial + 15))){
       if (RB3 == 0){
           RB3 = 1;  // lit LED
else if((val_Y_Final < (val_Y_Initial - 15))|| (val_Y_Final > (val_Y_Initial + 15))){
       if (RB3 == 0){
          RB3 = 1;   // lit LED
else{
      if ((val_Z_Final < (val_Z_Initial - 15))|| (val_Z_Final > (val_Z_Initial + 15))){
             if (RB3 == 0){
                 RB3 = 1;  // lit LED
Note: Able to find Tilt and Vibrate of device but not moving the device (i.e. linear motion of the device)
Any help will be highly appreciated.
Thanks
