File sink result is wrong after add FMCOMMS2 blocks
Question asked by mr_nazrin on Feb 8, 2018
Latest reply on Feb 11, 2018 by mr_nazrin
Hi Community team,
I construct a simple flowgraph that save real and imaginary data from a signal source. The flowgraph is QT GUI with amplitude set to 0.5 and frequency is 1000 as shown in figure below. Then I verify the data from .dat files by run python scripts and show similar and consistent value what I expected. Where I can calculate magnitude is ~0.5.
no fmcomms2
Then I added FMCOMMS2 source / sink into same flowgraph as shown in figure below. I did a similar verification process. I found that the result is wrong. I believe the Head block is the root cause , but if i removed this Head block, I will get/ need to process a huge amount of .dat file generated ( xxMByte).
with fmcomss2
Then I verify again using Time Sink after FMCOMMS2 Source ( remove head block ), the waveform is look good with magnitude ~0.5.
My aim is to get correct data in real.dat and imaginary.dat after add FMCOMMS2 blocks / Head block. Any one have some idea how to solve this issue?
Thank you
