Address setting of ADuC7060
Question asked by henry-tang on Feb 8, 2018
Latest reply on Mar 13, 2018 by barryzhang
Hi ADI Experter,
Normally, the address can be configured using hardware pin, but I found that we need to set address 0x0918 & 0x091C to determine ADuC7060's slave address.
These two registers have default value so I can assume what's slave address is.
If I uses two chips and connect them on same I2C bus, how can I recognize and set address before change register?
Or can I write different setting in ADuC7060's flash and the address setting will be different after boot up?
Thank you very much!
Henry
