Fastlock Pin control
Question asked by s.kannan on Feb 8, 2018
Latest reply on Feb 13, 2018 by s.kannan
It is mentioned in the reference manual that CTRL_IN0, CTRL_IN1 and CTRL_IN2 pins can be used to select a profile by setting 0x03 in register 0x29A(Tx) and 0x25A(Rx). I tried the same method in shell script and the registers were automatically self clearing back to 0x01( initially i put 0x03) and profiles are not changing.
Whats going wrong here? Is there any procedure to follow?
I also  take a look at the script mentioned in this link:https://github.com/analogdevicesinc/linux_image_ADI-scripts/blob/master/test_tx_fastlock_pinctrl.sh
In this code i) the gpio number for control input pins itself is wrong
ii) instead of ctrl_in0,ctrl_in1,ctrl_in2 pins they are using ctrl_in3,ctrl_in2,ctrl_in1 pins
iii) they didn't set the registers 0x25A or 0x29A anywhere in that program. How will you set the register ? Is there any API commands for that, or we are forced to use direct_reg_access?
