python script is waiting forever after add fmcomms2 iio blocks
Question asked by mr_nazrin on Feb 2, 2018
Latest reply on Feb 7, 2018 by travisfcollins
Dear Community Team,
I construct a simple magnitude measurement of signal source to obtain  frequency and amplitude sweep response. I used No GUI, Run to Completion so that I can add/modify generated python code in order me to add python features, like numpy , matplotlib etc.. The initial structure as shown in figure below.
simple signal source
Then I developed a program and run the python script and successful plotted as what I’m expected.
sweep response
Now I just add FMCOMMS2 sink and source as shown in figure below.
signal source with fmcomms2
Basically its just add those two blocks and some modification on self.connect. Overall program is similar as initial program above.
blocks added
Now the problem is the program is wait forever/hang up after execute the python script.
Then I find the possibility root cause is tb.wait() where my program is stuck here after I add iio_fmcomms2 blocks as shown in following figure.
where the x spot
If I disable/remove iio_fmcomms2 block and restore connection without fmcomms2 block, I able to run again without a problem.
There is something parameters should I define on fmcomms2 block? Buffer size maybe ? I also referring to https://gnuradio.org/doc/doxygen/page_operating_fg.html  for tb.wait() issue.
Fyi backgound: Zedboard + FMCOMMS2 , running on VM Ubuntu 32 bit, Remote PC connection
Best Regards,
