SSM3582, speaker output stops when operating one-side DAC OFF/ON.
Question asked by Euglena on Feb 2, 2018
Latest reply on Apr 3, 2018 by Euglena
On the SSM3852, I encounter unexpected behavior.
Could you please check below?
When setting the one-side DAC channel OFF and setting ON again, the speaker output stops with the over current.
On the evaluation board, we can reproduce the behavior.
Are following operations unexpected on the SSM3582?
When controlling the on-side DAC channel ON/OFF, does it cause any errors (for example, current leakage occur)?
< Environment >
PC
  - Sigma Studio Version 3.15 Build 3. Rev 1741 (9/29/2017)
  - foorbar2000 v1.3.17
USB to SPDIF Optical adapter
EVAL-SSM3582Z REV 1
  - PVDD 12V is provided
< Audio source >
PCM 44.1KHz 16bit
< Operation >
(1). On the evaluation board, connect power supply and  push RESET button
(2). On the SigmaStudio, do the followings
 - Tag "CHIP/SAI/DAC Control", Full software reset
    "NORMAL" -> "SW RST"
    "SW RST" -> "NORMAL"
 - "Read All"
 - Tag "FAULT/Status", Over current fault auto-recovery control
    "Auto" -> "Manual"
(3). On the PC, on the foobar2000, "Play"
(4). On the SigmaStudio, do the followings
 - Tag "CHIP/SAI/DAC Control", Software master powered
    "OFF" -> "ON"
        -----------> Sound Output
 - Tag "CHIP/SAI/DAC Control", Right channel (or Left channel),
    "ON" -> "OFF"
        -----------> No Sound Output
    "OFF" -> "ON"
 - Tag "FAULT/Status" Over current fault auto-recovery control
    Manual -> AUTO
        -----------> Sound Output (Recovered)
