ADV7611  read VIC
Question asked by jianghong on Jan 26, 2018
Latest reply on Jan 31, 2018 by Poornima
I just need the HDMI input signal,The configuration order is as follows:
  98 FF 80 ; I2C reset
  56 17 02 ; Encoder reset
 /*Sample new ALSB value for IO map */
   98 1B 01 ; Sample new ALSB value
   98  F4 80; // CEC
   98 F5 7C ; //INFORAME
   98 F8 4C; //DPLL
  98 F9 64 ; // KSV
  98 FA 6C ; //EDID
  98 FB 7C // HDMI
  98 FD 44 // CP
 There is a default configuration of 1080x50I,
/* Set VID_STD(IO Map 0x00[5:0]): 010100b=0x14 -> HD 1x1 -> 1920 x 1080 */
write_adv7611( fd, 0x98, 0x00, 0x14 );
/* Set VFREQ(IO Map 0x01[6:4]):
write_adv7611( fd, 0x98 , 0x01, 0x15 );
write_adv7611( fd, 0x98, 0x02, 0xF4 );
write_adv7611( fd, 0x98, 0x03, 0x80 ); /* 16-bit ITU-656 SDR mode */
write_adv7611( fd, 0x98, 0x05, 0x2C ); /* AV Codes On */
write_adv7611( fd, 0x98, 0x06, 0xA6 );
write_adv7611( fd, 0x98, 0x0B, 0x44 ); /* Power up part */
write_adv7611( fd, 0x98, 0x0C, 0x42 ); /* Power up part */
write_adv7611( fd, 0x98, 0x14, 0x7F ); /* Max Drive Strength */
write_adv7611( fd, 0x98, 0x15, 0x80 ); /* Disable Tristate of Pins */
write_adv7611( fd, 0x98, 0x19, 0x83 ); /* LLC DLL phase */
write_adv7611( fd, 0x98, 0x33, 0x40 ); /* LLC DLL enable */
write_adv7611( fd, 0x98, 0xBA, 0x01 );  /* Set HDMI FreeRun */
write_adv7611( fd, l0x98, 0x9B, 0x03 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC1, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC2, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC3, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC4, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC5, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC6, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC7, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC8, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xC9, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xCA, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xCB, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0xCC, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x00, 0x00 ); /* Set HDMI Input Port A */
write_adv7611( fd, l0x98, 0x83, 0xFE ); /* Enable clock terminator */
write_adv7611( fd, l0x98, 0x6F, 0x0C ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x85, 0x1F ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x87, 0x70 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x8D, 0x04 ); /* LFG */
write_adv7611( fd, l0x98, 0x8E, 0x1E ); /* HFG */
write_adv7611( fd, l0x98, 0x1A, 0x8A ); /* unmute audio */
write_adv7611( fd, l0x98, 0x57, 0xDA ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x58, 0x01 ); /* ADI recommended setting */
write_adv7611( fd, l0x98, 0x03, 0x98 ); /* DIS_I2C_ZERO_COMPR */
write_adv7611( fd, l0x98, 0x75, 0x10 ); /* DDC drive strength */
After the aforementioned configuration, the VIC is read and the corresponding resolution setting based on the VIC:
HDMI input signal :1080ix50:
0x6f[0] = 1    cable:
0x6a[4] = 1   hdmi clock:
0x04[1] = 1  pll lock:
0x05[7] = 1 HDMI
0x05[6] = 1 not HDCP encrypted
0x07[5] = 1 DE regeneration locked to incoming DE
0x44 0xB1[7] =  0 : Sync Channel 1 STDI measurements are not valid measurements
CH1_BL = 0x1fff
CH1_LCVS = 0
CH1_LCF  = 0
CH1_FCL = 0
CH1_STDI_INTLCD 0x44 0xB2[6]  = 1 : Indicates a signal on Sync Channel 1 with interlaced timing
VIC :  20
HDMI input signal :1080Px60:
0x6f[0] = 1    cable:
0x05[7] = 0 DVI
CH1_BL = 0x1fff
CH1_BL  = 0
CH1_LCVS  = 0
CH1_LCF =0
CH1_FCL = 0
VIC : 0
