Adv7611's LLC Clock Unstability
Question asked by JackyFeng on Jan 22, 2018
Latest reply on Jan 26, 2018 by GuenterL
In our application, if HDMI source is attached, LLC Clock has ranged from 72M Hz to 74.25MHz all through. If HDMI source is removed, the clock of LLC Clock is 74. 28M Hz and it is stable.The termination resistors of clock and data output are 22 ohm. The following is the setting of adv7611..
adv7611_write(0x98, 0xFF, 0x80); // I2C reset
adv7611_write(0x98, 0xF4, 0x80); // CEC
adv7611_write(0x98, 0xF5, 0x7C); // INFOFRAME
adv7611_write(0x98, 0xF8, 0x4C); // DPLL
adv7611_write(0x98, 0xF9, 0x64); // KSV
adv7611_write(0x98, 0xFA, 0x6C); // EDID
adv7611_write(0x98, 0xFB, 0x68); // HDMI
adv7611_write(0x98, 0xFD, 0x44); // CP
adv7611_write(0x98, 0x00, 0x13);
adv7611_write(0x98, 0x01, 0x05);
adv7611_write(0x98, 0x02, 0xF5);
adv7611_write(0x98, 0x03, 0x80);
adv7611_write(0x98, 0x04, 0x62);
adv7611_write(0x98, 0x05, 0x2c); // AV Codes On
adv7611_write(0x98, 0x06, 0xA6); // Invert VS,HS pins
adv7611_write(0x98, 0x0B, 0x44); // Power up part
adv7611_write(0x98, 0x0C, 0x42); // Power up part
adv7611_write(0x98, 0x14, 0x7f); // Max Drive Strength
adv7611_write(0x98, 0x15, 0x80); // Disable Tristate of Pins
adv7611_write(0x98, 0x19, 0x89); // LLC DLL phase
adv7611_write(0x98, 0x33, 0x40); // LLC DLL enable
// adv7611_write(0x98, 0x8e, 0x80); // equalizer
// adv7611_write(0x98, 0x96, 0x00); // equalizer
adv7611_write(0x44, 0xBA, 0x01); // Set HDMI FreeRun
adv7611_write(0x64, 0x40, 0x81); // Disable HDCP 1.1 features
adv7611_write(0x44, 0x6C, 0x00); // cp map adi recommended setting
adv7611_write(0x68, 0x9B, 0x03); // ADI recommended setting
adv7611_write(0x68, 0xC1, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC2, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC3, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC4, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC5, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC6, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC7, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC8, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xC9, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xCA, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xCB, 0x01); // ADI recommended setting
adv7611_write(0x68, 0xCC, 0x01); // ADI recommended setting
adv7611_write(0x68, 0x00, 0x00); // Set HDMI Input Port A
adv7611_write(0x68, 0x83, 0xFE); // Enable clock terminator for port A
adv7611_write(0x68, 0x6F, 0x0C); // ADI recommended setting
adv7611_write(0x68, 0x85, 0x1F); // ADI recommended setting
adv7611_write(0x68, 0x87, 0x70); // ADI recommended setting
adv7611_write(0x68, 0x8D, 0x04); // LFG
adv7611_write(0x68, 0x8E, 0x1E); // HFG
adv7611_write(0x68, 0x1A, 0x8A); // unmute audio
adv7611_write(0x68, 0x57, 0xDA); // ADI recommended setting
adv7611_write(0x68, 0x58, 0x01); // ADI recommended setting
adv7611_write(0x68, 0x03, 0x98); // DIS_I2C_ZERO_COMPR
adv7611_write(0x68, 0x75, 0x10); // DDC drive strength
I have the other question:  Should 1.8V supplies be power up after 3.3V?
Best reguads.
Jacky
