Need Help for LTC7004
Question asked by viji0789 on Jan 19, 2018
Latest reply on Jan 22, 2018 by Gene323
We are using above circuit for 48V load ON/OFF control
We are facing one problem if i am enable INP pin through micro controller i got 48V as output
If i am disable INP i got 11.5V as ouput.
But i am connecting 10K resistor on MOSFET sorce  side with respect to GND,now i got 0V as output
Why i am getting 11.5V floating voltage as ouput??
I can't understand below point in datasheet,Can you explain it?
TS (Pin 8):Top (High Side) source connection or GND if
used in ground referenced applications
Can you give me solution for above points?
