HMC394LP4E & HMC365SG8E
Question asked by sss on Jan 19, 2018
Latest reply on Jan 25, 2018 by sss
Hi all,
Our customer will consider to design the programmable divider circuit, divide by 48, with HMC394 & HMC365.
Input signal : sine wave,  1536MHz
Following is questions,
1.What is the each input/output impeadance ? 50 ohm ?
 HMC394 :input ? ohm / output ? ohm
 HMC365 :input ? ohm / output ? ohm
2.About HMC365SG8E, Duty cicle 50 % of Input signal have to enaght ?
Does the input signal of HMC365 must be duty 50%?
If it is 50% or more or less (eg 30%, 70%), will the HMC365 work normally?
3.Following is work normally,  total divide by 48 ?
sine wave, 1536MHz input >>> HMC394LP4E (divide by 12) >>> AC coupling >>> HMC365SG8E (divide by 4) >>> output
or
sine wave, 1536MHz input >>> HMC365SG8E (divide by 4)>>> AC coupling >>> HMC394LP4E (divide by 12) >>> output
sss
