Stuck setting up ADF5355
Question asked by chrisfrederickson on Jan 18, 2018
Latest reply on Feb 2, 2018 by chrisfrederickson
Hello. I'm working to get the Linux driver for the ADF5355 working on the Raspberry Pi Compute Module 3 and am stuck. I have compiled the driver as a module and am using the device tree overlay below. There is a device in /sys/bus/spi/devices/spi0.0 that when running cat modalias return spi:adf5355 and looking at uevent returns:
OF_NAME=adf5355
OF_FULLNAME=/soc/spi@7e204000/adf5355@0
OF_COMPATIBLE_0=adi,adf5355
OF_COMPATIBLE_N=1
MODALIAS=spi:adf5355
The module is not being automatically loaded and adding printks to each function in the module, it looks like none of them are being called. I'm not entirely sure where to go from here. Am I doing something obviously wrong?
// Overlay for ADF5355
/ dts - v1 / ;
/ plugin / ;
compatible = "brcm,bcm2708";
fragment @0
target = <&spidev0>;
__overlay__
status = "disabled";
fragment @1
target - path = "/";
__overlay__
adf5355_clkin:
osc:
oscillator
compatible = "fixed-clock";
#clock - cells = < 1 > ;
clock - frequency = <1000000>;
clock - output - names = "osc";
fragment @2
__overlay__
adf5355_reg:
fixedregulator @0
compatible = "regulator-fixed";
regulator - name = "adf5355-reg";
regulator - min - microvolt = <3300000>;
regulator - max - microvolt = <3300000>;
fragment @3
target = <&spi0>;
__overlay__
#address - cells = < 1 > ;
#size - cells = < 0 > ;
status = "okay";
adf5355 @0
status = "okay";
compatible = "adi,adf5355";
reg = <0>;
spi - max - frequency = <1000000>;
clocks = <&adf5355_clkin>;
clock - output - names = "adf5355_out";
vcc - supply = <&adf5355_reg>;
adi, charge - pump - current = <900>;
adi, muxout - select = <6>;
adi, mute - till - lock - enable;
adi, output - a - power = <2>;
adi, output - b - power = <2>;
adi, output - b - enable;
adi, output - a - enable;
adi, charge - pump - negative - bleed - enable;
adi, reference - differential - input - enable;
adi, muxout - level - 3v3 - enable;
adi, power - up - frequency = / bits / 64 < 123000000 > ;
