LTC2946 output questions
Question asked by greydesk on Jan 17, 2018
Latest reply on Jan 18, 2018 by greydesk
I am using an LTC2946 as part of a final year Electrical and Computer Engineering project. I am communicating with the chip over I2C using an ATMega 328P. I can talk to the chip and read values from it however, the following question remain:
1. How quickly should the Timer Counter value update? Mine updates about every 4 seconds. This seems low.
2. I have a separate 5V supply running into pins 1 and 2. I am trying to sense voltage between 20 and 40V at the sense+ pin. I don't seem to get any rational value. I can provide register settings and such if needed. Can someone point me to a simple voltage measurement setup for this chip?
Current pin connections:
1 - VDD - 5V
2 - IntVcc - 5V
3 - GPIO1 - GND
4 - GPIO2 - GND
5 - GPIO3 - Floating - will be used as ALERT pin in final design but not yet implemented.
6 - SDA0 - SDA
7 - SDA1 - SDA
8 - SCL - SCL
9 - CLKIN - Floating
10 - CLKOUT - Floating
11 - GND - GND
12 - ADR0 - GND
13 - ADIN - GND
14 - ADR1 - GND
15 - SENSE- - Floating
16 - SENSE+ - 20V
Thanks!
