SSM3582 Broken Audio When driving Different Speakers
Question asked by tmawson on Jan 16, 2018
Latest reply on Jan 17, 2018 by tmawson
I have a project that uses an SSM3582 in my PCB design (which is based off the SSM3582 Eval PCB).  It has been driving 8 ohm speakers with good-sounding audio but now I've tried it with speakers from my customer that use a crossover network and the audio is badly broken up (stuttering).  This effect is the same if I use my PCB or the SSM3582 Eval PCB.  I have attached a screen capture of SigmaStudio so you can see my settings.
Does anyone have suggestions on what might be causing this issue, any register settings to tweak, etc.
My register settings are as follows:
Reg
Name
Bits
What to write
Notes
0x04
Pwr_Ctrl
APwDn_En, R, Temp_PwDn, Stereo, R_PwDn, L_PwDn, R, SPwDn
0xF1
B0 to 0 to power on. B7 is Temp_PwDn
0x05
Amp_DAC_Ctrl
DAC_LPM, R, DAC_Pol_R, DAC_Pol_L, Edge, R, Ana_Gain:2
0x8A
B1..0 = Analog_Gain
0x06
DAC_Ctrl
DAC_HVC, DAC_Mute_R, DAC_Mute_L, DAC_HPF, R, DAC_Samp_Rate:3
0x03
B2..0 = Sample rate (3=96k)
0x07
Vol_L_Ctrl
0xFF - 0x00 = Mute - +24 dB
0x40
Default is 0x40 = 0 dB
0x08
Vol_R_Ctrl
0x40
0x09
SAI_Ctrl1
R, BClk_Pol, TDM_Slot_Wdth:3, Fsync_Mode, Sdat_Fmt, SAI_Mode
0x01
0x0A
SAI_Ctrl2
Sdata_Edge, R, R, Data_Width, Vol_ZC, Clip_Lnk, Vol_Lnkd, Auto_Slot
0x17
Ted
