ADV7611 YUV Parallel no output
Question asked by EricWu on Jan 15, 2018
Latest reply on Jan 31, 2018 by Poornima
Hello :
I'm now debugging ADV7611 , the layout would be Sport Camera  ->  (HDMI) -> ADV7611 -> (YUV Parallel) -> Vin Interface
now I force Sport Camera output 1080P30 format , but Vin can't receive data correctly,
Would you have a look what's going on with my script ?
Also I have done some trouble shooting below.
    {0x98, 0xFF, 0x80}, /* I2C reset */
    {0x98, 0xF4, 0x80}, /* CEC */
    {0x98, 0xF5, 0x7C}, /* INFOFRAME */
    {0x98, 0xF8, 0x4C}, /* DPLL */
    {0x98, 0xF9, 0x64}, /* KSV */
    {0x98, 0xFA, 0x6C}, /* EDID */
    {0x98, 0xFB, 0x68}, /* HDMI */
    {0x98, 0xFD, 0x44}, /* CP */
    {0x98, 0x00, 0x1E}, /* Prim_Mode =1920x1080 */
    {0x98, 0x01, 0x25}, /*  30 HZ HDMI-COMP */
    {0x98, 0x02, 0xF7}, /* Auto CSC, YCrCb out, Set op_656 bit */
    {0x98, 0x03, 0x80}, /* 16 bit SDR 422 Mode 0 */
    {0x98, 0x05, 0x28}, /* AV Codes Off */
    {0x98, 0x06, 0xA6}, /* Invert VS,HS pins */
    {0x98, 0x0B, 0x44}, /* Power up part */
    {0x98, 0x0C, 0x42}, /* Power up part */
    {0x98, 0x14, 0x7F}, /* Max Drive Strength */
    {0x98, 0x15, 0x80}, /* Disable Tristate of Pins */
    {0x98, 0x19, 0x8A}, /* LLC DLL phase */
    {0x98, 0x33, 0x40}, /* LLC DLL enable */
    {0x44, 0xBA, 0x01}, /* Set HDMI FreeRun */
    {0x44, 0xC9, 0x2D}, /* DIS_AUTO_PARAM_BUFF */
    {0x44, 0xBF, 0x13},
    {0x64, 0x40, 0x81}, /* Disable HDCP 1.1 features */
    {0x68, 0x9B, 0x03}, /* ADI recommended setting */
    {0x68, 0xC1, 0x01}, /* ADI recommended setting */
    {0x68, 0xC2, 0x01}, /* ADI recommended setting */
    {0x68, 0xC3, 0x01}, /* ADI recommended setting */
    {0x68, 0xC4, 0x01}, /* ADI recommended setting */
    {0x68, 0xC5, 0x01}, /* ADI recommended setting */
    {0x68, 0xC6, 0x01}, /* ADI recommended setting */
    {0x68, 0xC7, 0x01}, /* ADI recommended setting */
    {0x68, 0xC8, 0x01}, /* ADI recommended setting */
    {0x68, 0xC9, 0x01}, /* ADI recommended setting */
    {0x68, 0xCA, 0x01}, /* ADI recommended setting */
    {0x68, 0xCB, 0x01}, /* ADI recommended setting */
    {0x68, 0xCC, 0x01}, /* ADI recommended setting */
    {0x68, 0x00, 0x00}, /* Set HDMI Input Port A */
    {0x68, 0x83, 0xFE}, /* Enable clock terminator for port A */
    {0x68, 0x6F, 0x08}, /* ADI recommended setting */
    {0x68, 0x85, 0x1F}, /* ADI recommended setting */
    {0x68, 0x87, 0x70}, /* ADI recommended setting */
    {0x68, 0x8D, 0x04}, /* LFG */
    {0x68, 0x8E, 0x1E}, /* HFG */
    {0x68, 0x1A, 0x8A}, /* unmute audio */
    {0x68, 0x57, 0xDA}, /* ADI recommended setting */
    {0x68, 0x58, 0x01}, /* ADI recommended setting */
    {0x68, 0x03, 0x98}, /* DIS_I2C_ZERO_COMPR */
    {0x68, 0x75, 0x10}, /* DDC drive strength */
    {0x68, 0x4C, 0x44}, /* NEW_VS_PARAM */
EDID
{0x64, 0x77, 0x00},
    {0x6C, 0x00, 0x00},
    {0x6C, 0x01, 0xFF},
    {0x6C, 0x02, 0xFF},
    {0x6C, 0x03, 0xFF},
    {0x6C, 0x04, 0xFF},
    {0x6C, 0x05, 0xFF},
    {0x6C, 0x06, 0xFF},
    {0x6C, 0x07, 0x00}, //8
    {0x6C, 0x08, 0x06},
    {0x6C, 0x09, 0x8F},
    {0x6C, 0x0A, 0x07},
    {0x6C, 0x0B, 0x11},
    {0x6C, 0x0C, 0x01},
    {0x6C, 0x0D, 0x00},
    {0x6C, 0x0E, 0x00},
    {0x6C, 0x0F, 0x00}, //16
    {0x6C, 0x10, 0x17},
    {0x6C, 0x11, 0x11},
    {0x6C, 0x12, 0x01},
    {0x6C, 0x13, 0x03},
    {0x6C, 0x14, 0x80},
    {0x6C, 0x15, 0x0C},
    {0x6C, 0x16, 0x09},
    {0x6C, 0x17, 0x78}, //24
    {0x6C, 0x18, 0x0A},
    {0x6C, 0x19, 0x1E},
    {0x6C, 0x1A, 0xAC},
    {0x6C, 0x1B, 0x98},
    {0x6C, 0x1C, 0x59},
    {0x6C, 0x1D, 0x56},
    {0x6C, 0x1E, 0x85},
    {0x6C, 0x1F, 0x28}, //32
    {0x6C, 0x20, 0x29},
    {0x6C, 0x21, 0x52},
    {0x6C, 0x22, 0x57},
    {0x6C, 0x23, 0x00},
    {0x6C, 0x24, 0x00},
    {0x6C, 0x25, 0x00},
    {0x6C, 0x26, 0x01},
    {0x6C, 0x27, 0x01}, //40
    {0x6C, 0x28, 0x01},
    {0x6C, 0x29, 0x01},
    {0x6C, 0x2A, 0x01},
    {0x6C, 0x2B, 0x01},
    {0x6C, 0x2C, 0x01},
    {0x6C, 0x2D, 0x01},
    {0x6C, 0x2E, 0x01},
    {0x6C, 0x2F, 0x01}, //48
    {0x6C, 0x30, 0x01},
    {0x6C, 0x31, 0x01},
    {0x6C, 0x32, 0x01},
    {0x6C, 0x33, 0x01},
    {0x6C, 0x34, 0x01},
    {0x6C, 0x35, 0x01},
    {0x6C, 0x36, 0x8C},
    {0x6C, 0x37, 0x0A}, //56
    {0x6C, 0x38, 0xD0},
    {0x6C, 0x39, 0x8A},
    {0x6C, 0x3A, 0x20},
    {0x6C, 0x3B, 0xE0},
    {0x6C, 0x3C, 0x2D},
    {0x6C, 0x3D, 0x10},
    {0x6C, 0x3E, 0x10},
    {0x6C, 0x3F, 0x3E}, //64
    {0x6C, 0x40, 0x96},
    {0x6C, 0x41, 0x00},
    {0x6C, 0x42, 0x81},
    {0x6C, 0x43, 0x60},
    {0x6C, 0x44, 0x00},
    {0x6C, 0x45, 0x00},
    {0x6C, 0x46, 0x00},
    {0x6C, 0x47, 0x18}, //72
    {0x6C, 0x48, 0x01},
    {0x6C, 0x49, 0x1D},
    {0x6C, 0x4A, 0x80},
    {0x6C, 0x4B, 0x18},
    {0x6C, 0x4C, 0x71},
    {0x6C, 0x4D, 0x1C},
    {0x6C, 0x4E, 0x16},
    {0x6C, 0x4F, 0x20}, //80
    {0x6C, 0x50, 0x58},
    {0x6C, 0x51, 0x2C},
    {0x6C, 0x52, 0x25},
    {0x6C, 0x53, 0x00},
    {0x6C, 0x54, 0x81},
    {0x6C, 0x55, 0x49},
    {0x6C, 0x56, 0x00},
    {0x6C, 0x57, 0x00}, //88
    {0x6C, 0x58, 0x00},
    {0x6C, 0x59, 0x9E},
    {0x6C, 0x5A, 0x00},
    {0x6C, 0x5B, 0x00},
    {0x6C, 0x5C, 0x00},
    {0x6C, 0x5D, 0xFC},
    {0x6C, 0x5E, 0x00},
    {0x6C, 0x5F, 0x56}, //96
    {0x6C, 0x60, 0x41},
    {0x6C, 0x61, 0x2D},
    {0x6C, 0x62, 0x31},
    {0x6C, 0x63, 0x38},
    {0x6C, 0x64, 0x30},
    {0x6C, 0x65, 0x39},
    {0x6C, 0x66, 0x41},
    {0x6C, 0x67, 0x0A}, //104
    {0x6C, 0x68, 0x20},
    {0x6C, 0x69, 0x20},
    {0x6C, 0x6A, 0x20},
    {0x6C, 0x6B, 0x20},
    {0x6C, 0x6C, 0x00},
    {0x6C, 0x6D, 0x00},
    {0x6C, 0x6E, 0x00},
    {0x6C, 0x6F, 0xFD}, //112
    {0x6C, 0x70, 0x00},
    {0x6C, 0x71, 0x17},
    {0x6C, 0x72, 0x3D},
    {0x6C, 0x73, 0x0D},
    {0x6C, 0x74, 0x2E},
    {0x6C, 0x75, 0x11},
    {0x6C, 0x76, 0x00},
    {0x6C, 0x77, 0x0A}, //120
    {0x6C, 0x78, 0x20},
    {0x6C, 0x79, 0x20},
    {0x6C, 0x7A, 0x20},
    {0x6C, 0x7B, 0x20},
    {0x6C, 0x7C, 0x20},
    {0x6C, 0x7D, 0x20},
    {0x6C, 0x7E, 0x01},
    {0x6C, 0x7F, 0x1C}, //128
    {0x6C, 0x80, 0x02},
    {0x6C, 0x81, 0x03},
    {0x6C, 0x82, 0x33},
    {0x6C, 0x83, 0x71},
    {0x6C, 0x84, 0x4C},
    {0x6C, 0x85, 0x02},
    {0x6C, 0x86, 0x05},
    {0x6C, 0x87, 0x04}, //136
    {0x6C, 0x88, 0x01},
    {0x6C, 0x89, 0xA2},
    {0x6C, 0x8A, 0x11},
    {0x6C, 0x8B, 0x14},
    {0x6C, 0x8C, 0x13},
    {0x6C, 0x8D, 0x06},
    {0x6C, 0x8E, 0x15},
    {0x6C, 0x8F, 0x03}, //144
    {0x6C, 0x90, 0x12},
    {0x6C, 0x91, 0x35},
    {0x6C, 0x92, 0x0F},
    {0x6C, 0x93, 0x7F},
    {0x6C, 0x94, 0x07},
    {0x6C, 0x95, 0x17},
    {0x6C, 0x96, 0x1F},
    {0x6C, 0x97, 0x38}, //152
    {0x6C, 0x98, 0x1F},
    {0x6C, 0x99, 0x07},
    {0x6C, 0x9A, 0x30},
    {0x6C, 0x9B, 0x2F},
    {0x6C, 0x9C, 0x07},
    {0x6C, 0x9D, 0x72},
    {0x6C, 0x9E, 0x3F},
    {0x6C, 0x9F, 0x7F}, //160
    {0x6C, 0xA0, 0x72},
    {0x6C, 0xA1, 0x57},
    {0x6C, 0xA2, 0x7F},
    {0x6C, 0xA3, 0x00},
    {0x6C, 0xA4, 0x37},
    {0x6C, 0xA5, 0x7F},
    {0x6C, 0xA6, 0x72},
    {0x6C, 0xA7, 0x83}, //168
    {0x6C, 0xA8, 0x4F},
    {0x6C, 0xA9, 0x00},
    {0x6C, 0xAA, 0x00},
    {0x6C, 0xAB, 0x67},
    {0x6C, 0xAC, 0x03},
    {0x6C, 0xAD, 0x0C},
    {0x6C, 0xAE, 0x00},
    {0x6C, 0xAF, 0x10}, //176
    {0x6C, 0xB0, 0x00},
    {0x6C, 0xB1, 0x88},
    {0x6C, 0xB2, 0x2D},
    {0x6C, 0xB3, 0x00},
    {0x6C, 0xB4, 0x00},
    {0x6C, 0xB5, 0x00},
    {0x6C, 0xB6, 0x00},
    {0x6C, 0xB7, 0xFF}, //184
    {0x6C, 0xB8, 0x00},
    {0x6C, 0xB9, 0x0A},
    {0x6C, 0xBA, 0x20},
    {0x6C, 0xBB, 0x20},
    {0x6C, 0xBC, 0x20},
    {0x6C, 0xBD, 0x20},
    {0x6C, 0xBE, 0x20},
    {0x6C, 0xBF, 0x20}, //192
    {0x6C, 0xC0, 0x20},
    {0x6C, 0xC1, 0x20},
    {0x6C, 0xC2, 0x20},
    {0x6C, 0xC3, 0x20},
    {0x6C, 0xC4, 0x20},
    {0x6C, 0xC5, 0x20},
    {0x6C, 0xC6, 0x00},
    {0x6C, 0xC7, 0x00}, //200
    {0x6C, 0xC8, 0x00},
    {0x6C, 0xC9, 0xFF},
    {0x6C, 0xCA, 0x00},
    {0x6C, 0xCB, 0x0A},
    {0x6C, 0xCC, 0x20},
    {0x6C, 0xCD, 0x20},
    {0x6C, 0xCE, 0x20},
    {0x6C, 0xCF, 0x20}, //208
    {0x6C, 0xD0, 0x20},
    {0x6C, 0xD1, 0x20},
    {0x6C, 0xD2, 0x20},
    {0x6C, 0xD3, 0x20},
    {0x6C, 0xD4, 0x20},
    {0x6C, 0xD5, 0x20},
    {0x6C, 0xD6, 0x20},
    {0x6C, 0xD7, 0x20}, //216
    {0x6C, 0xD8, 0x00},
    {0x6C, 0xD9, 0x00},
    {0x6C, 0xDA, 0x00},
    {0x6C, 0xDB, 0xFF},
    {0x6C, 0xDC, 0x00},
    {0x6C, 0xDD, 0x0A},
    {0x6C, 0xDE, 0x20},
    {0x6C, 0xDF, 0x20}, //224
    {0x6C, 0xE0, 0x20},
    {0x6C, 0xE1, 0x20},
    {0x6C, 0xE2, 0x20},
    {0x6C, 0xE3, 0x20},
    {0x6C, 0xE4, 0x20},
    {0x6C, 0xE5, 0x20},
    {0x6C, 0xE6, 0x20},
    {0x6C, 0xE7, 0x20}, //232
    {0x6C, 0xE8, 0x20},
    {0x6C, 0xE9, 0x20},
    {0x6C, 0xEA, 0x00},
    {0x6C, 0xEB, 0x00},
    {0x6C, 0xEC, 0x00},
    {0x6C, 0xED, 0x00},
    {0x6C, 0xEE, 0x00},
    {0x6C, 0xEF, 0x00}, //240
    {0x6C, 0xF0, 0x00},
    {0x6C, 0xF1, 0x00},
    {0x6C, 0xF2, 0x00},
    {0x6C, 0xF3, 0x00},
    {0x6C, 0xF4, 0x00},
    {0x6C, 0xF5, 0x00},
    {0x6C, 0xF6, 0x00},
    {0x6C, 0xF7, 0x00}, //248
    {0x6C, 0xF8, 0x00},
    {0x6C, 0xF9, 0x00},
    {0x6C, 0xFA, 0x00},
    {0x6C, 0xFB, 0x00},
    {0x6C, 0xFC, 0x00},
    {0x6C, 0xFD, 0x00},
    {0x6C, 0xFE, 0x00},
    {0x6C, 0xFF, 0xE9}, //256
    {0x64, 0x77, 0x00},
    {0x64, 0x52, 0x20},
    {0x64, 0x53, 0x00},
    {0x64, 0x70, 0x9E},
    {0x64, 0x74, 0x03}
Some Trouble Shooting
1. IO Map R0x6F[0] is equal to 1 (detect cable in)
01  --> YES
2. IO Map R0x6A[4] is equal to 1 (detect HDMI Clock)
53 -->  YES
3. HDMI Map R0x04[1] is equal to 1 (is HDMI PLL lock)
23  --> YES
4. HDMI Map R0x05[6] is equal to 1 (HDMI encryption)
B0  --> NO
5. HDMI Map R0x07[5] is equal to 1 (De generation is lock)
A7 --> YES
------------------ STDI INFOMATION (FORMAT IDENTIFY)-------------------
6. Block Length CH1_BL[13:0]
This is the number of 28.6363 MHz clock cycles (XTAL frequency) in a block of eight lines. From this, the time duration of one line can be concluded.
CH1_BL
9A82 -> [5:0][7:0] 1A82 -> 6786
7. Line count in VSYNC CH1_LCVS[4:0]
The LCVS[4:0] readback value is the number of lines within one VSync period.
CH1_LCVS
28   -> [7:3] -> 5
8. Line count in Field CH1_LCF[10:0]
The CH1_LCF[10:0] readback value is the number of lines between two VSyncs, that is, over one field measured by channel.
CH1_LCF
0464 -> [3:0][7:0] -> 1124
9. Field Length CH1_FCL[12:0]
This is the number of 28.6363 MHz clock cycles in a 1/256th of a field. Alternately, this value of FCL multiplied by 256 gives one field
length count in 28.6363 MHz (XTAL) clocks.
CH1_FCL
0E94 -> [4:0][7:0] -> 3732
------------------ HDMI INPUT INFOMATION -------------------
10. Total line width is a horizontal synchronization measurement. This gives the total number of pixels per line. This measurement is valid only when the DE regeneration filter has locked.
TOTAL_LINE_WIDTH[13:0]
898 -> 2200
11. HSync front porch width is a horizontal synchronization measurement. The unit of this measurement is unique pixels. This measurement is valid only when the DE regeneration filter has locked.
HSYNC_FRONT_PORCH[12:0]
58 -> 88
12. HSync pulse width is a horizontal synchronization measurement. The unit of this measurement is unique pixels. This measurement is valid only when the DE regeneration filter has locked.
HSYNC_PULSE_WIDTH[12:0]
2C -> 44
13. HSync Back Porch width is a horizontal synchronization measurement. The unit of this measurement is unique pixels. This measurement is valid only when the DE regeneration filter has locked.
HSYNC_BACK_PORCH[12:0]
94 -> 148
14. Field 0 total height is a vertical synchronization measurement. This readback gives the total number of half lines in Field 0. This measurement is valid only when the vertical filter has locked.
FIELD0_TOTAL_HEIGHT[13:0]
8CA -> 2250
15. Field 1 total height is a vertical synchronization measurement. This readback gives the total number of half lines in Field 1. This measurement is valid only when the vertical filter has locked. Field 1 measurements are valid when HDMI_INTERLACED is set to 1.
FIELD1_TOTAL_HEIGHT[13:0]
8CA -> 2250
16. Field 0 VSync front porch width is a vertical synchronization measurement. The unit of this measurement is half lines. This measurement is valid only when the vertical filter has locked.
FIELD0_VS_FRONT_PORCH[13:0]
08 -> 08
17. Field 1 VSync front porch width is a vertical synchronization measurement. The unit of this measurement is half lines. This measurement is valid only when the vertical filter has locked. Field 1 measurements are valid when HDMI_INTERLACED is set to 1
FIELD1_VS_FRONT_PORCH[13:0]
08 -> 08
18. Field 0 VSync width is a vertical synchronization measurement. The unit for this measurement is half lines. This measurement is valid only when the vertical filter has locked.
FIELD0_VS_PULSE_WIDTH[13:0]
0A -> 10
19. Field 1 VSync width is a vertical synchronization measurement. The unit for this measurement is half lines. This measurement is valid only when the vertical filter has locked. Field 1 measurements are valid when HDMI_INTERLACED is set to 1
FIELD1_VS_PULSE_WIDTH[13:0]
0A -> 10
I want to ask, from those information, ADV7611 can identify sport camera output ?
if ADV7611 can identify the input, I will check the Vin side setting,
Eric.
