ADSP BF 548 SPI Slave register accessing issue
Question asked by amar26121993 on Jan 9, 2018
Latest reply on Jan 19, 2018 by Jithul_Janardhanan
Iam using ADZS BF 548 Eval board in my project. iam using Visual DSP++ 5.1.2 trail version.
I am working to access a Slave Device through SPI interface, basic access involves write and read Registers of the slave device.
when i try to access the slave device by writting register level (SPI Registers of BF548) access code and perform write and read with slave device.
access to the slave device is working fine. the complete code was written in main functions. below is portion of code which is working
//----------Reg Write-------------------
  RegAddress=0x01;
  Reg_data1[0]=0x00;
  Reg_data1[1]=0x00;
  *pPORTB_CLEAR = PB9;
  SPI_Write((0x80|RegAddress));
  SPI_Write(Reg_data1[0]);
  SPI_Write(Reg_data1[1]);
  *pPORTB_SET = PB9;
  RegAddress=0x0F;
  Reg_data1[0]=0xFC;
  Reg_data1[1]=0xC0;
  *pPORTB_SET = PB9;
  RegAddress=0x11;
  Reg_data1[0]=0x12;
  Reg_data1[1]=0xCD;
  *pPORTB_SET = PB9;
  while(1)// reading registers in while loop
   RegAddress=0x00;
   HI_6136_Cmdtx(0x00|(RegAddress<<2));
   Readvalue1=SPI_Read();
   Readvalue2=SPI_Read();
   *pPORTB_SET = PB9;
   dataAcq =((Readvalue1<<8)|Readvalue2);
   printf("%04x\t",dataAcq);
   write_Mapreg(0x0b,0x0011);
   *pPORTB_SET = PB9;
   HI_6136_Cmdtx(0x40);
   *pPORTB_SET = PB9;
   write_Mapreg(0x0b,0x0019);
   *pPORTB_SET = PB9;
   *pPORTB_SET = PB9;
   write_Mapreg(0x0b,0x001C);
   *pPORTB_SET = PB9;
   *pPORTB_SET = PB9;
   Readvalue1=Readvalue2=0;
when i replaced the write and read code from main function to a separate function and called those read and write functions in the main function,
the access to slave device is not working and always i am reading 0x0000/0xFFFF. only change to working and not working is read and write was made
as separate functions. below is the protion of code which is not working
 WriteRegister(0,0x00,0xC050);
 WriteRegister(0,0x01,0x0000);
 WriteRegister(0,0xF,0xFCC0);
 WriteRegister(0,0x11,0xABCD);
 WriteRegister(0,0x1C,0x2468);
 WriteRegister(0,0x1D,0x1359);
      dataAcq= ReadRegister(0,0x0000);
         printf("%x\t",dataAcq);
  dataAcq = ReadRegister(0,0x0001);
  dataAcq = ReadRegister(0,0x000F);
  dataAcq = ReadRegister(0,0x0011);
  dataAcq = ReadRegister(0,0x001C);
  dataAcq = ReadRegister(0,0x001D);
also i found one more issue in the working code (i.e. access code written in main function), In between in the code(main.c) if a unwanted function is commented
and run code the access is giving a intermadiate error in read with reading 0x0000/0xFFFF in between. the function which are effecting defined above main function.
"write_low_reg_1(U8BIT a1, U16BIT a2)" and "SPI_READ_HOLT(unsigned short a3)" .
Does the function overhead making any issue?
please find the attached two files main.c and board_613x.c
SPI configuration
word length - 8 bit
data transfer - MSB sent first
SPI Clk - 22.2Mhz
SPI Mode - 0
kindly give your suggestion and suggest if any changes to be done.
thanks for your reply in advance.
Best regards
Amar TR
Software Engineer
SLN Technologies
