SIMD and aligned
Question asked by bookevg on Nov 18, 2011
Latest reply on Nov 25, 2011 by bookevg
I'm using ADSP21489.
As I understand ADSP21489 support SIMD and the start adress of memory could be odd, but the quantity of elements must be even.
In chapter "Implications of Using SIMD Mode" of Run-Time Library Manual for SHARC Processors mention that the start adress of memory must be even:
"If the variable ptr is initialized using ptr=&a[i] and the value of the scalar i is odd,
then you cannot use ptr to pass an array to a DSP library function."
My code:
#include "stats.h"
volatile float X[255];
volatile  float  K[255];
volatile  float  Y[255];
void main(void)
     for (;;)
          int pm *pk = (int pm *)&K[1];
          int dm *px = (int dm *)&X[1];
          int *py =  &Y[1];
          for (int i = 0; i < 254; i++)
                *py++ = (*pk++)*(*px++);
          rmsf(  &Y[1], 254  );
I can't understand about (What Prevents the Compiler From Automatically Exploiting
SIMD Mode of VisualDSP++ 5.0 C/C++ Compiler Manual for SHARC Processors, p.  1-273)
"The code accesses memory locations that are not double-word aligned"
Is it mean that the first address must be even or the quantity of elements must be even?
