Linker error when including Math function
Question asked by willrobot on Nov 15, 2011
Latest reply on Dec 8, 2011 by StuH
I've 2 simple function I've implemented that use sqrt and atan2 classic math function. I've tried to compile it (my linker is separate to the compiler) even with -lm option, I have the followingf linker error:
bfin-elf-ld -v  -o test_ad1836_driver -T  coreb_test_ad1836_driver.lds  --just-symbol  ../../icc_core/icc queue.o ezkit_561.o  heap_2.o  port.o tasks.o test_ad1836_driver.o list.o croutine.o user_isr.o bfin_isr.o app_c.o context_sl_asm.o cycle_count.o CFFT_Rad4_NS_NBRev.o math_tools.o -Ttext 0x3c00000 -L /opt/uClinux/bfin-elf/bfin-elf/lib -L /opt/uClinux/bfin-elf/bfin-elf/lib -lc -lm  -Map=test_ad1836_driver.map
argv[0]      = 'bfin-elf-ld'
bindir       = '/opt/uClinux/bfin-elf/bin/'
tooldir      = '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/'
linker       = '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/ld.real'
elf2flt      = '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/elf2flt'
nm           = '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/nm'
objdump      = '/opt/uClinux/bfin-elf/bin/bfin-elf-objdump'
objcopy      = '/opt/uClinux/bfin-elf/bin/bfin-elf-objcopy'
ldscriptpath = '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/../lib'
Invoking: '/opt/uClinux/bfin-elf/bin/../bfin-elf/bin/ld.real' '-v' '-o' 'test_ad1836_driver' '-T' 'coreb_test_ad1836_driver.lds' '--just-symbol' '../../icc_core/icc' 'queue.o' 'ezkit_561.o' 'heap_2.o' 'port.o' 'tasks.o' 'test_ad1836_driver.o' 'list.o' 'croutine.o' 'user_isr.o' 'bfin_isr.o' 'app_c.o' 'context_sl_asm.o' 'cycle_count.o' 'CFFT_Rad4_NS_NBRev.o' 'math_tools.o' '-Ttext' '0x3c00000' '-L' '/opt/uClinux/bfin-elf/bfin-elf/lib' '-L' '/opt/uClinux/bfin-elf/bfin-elf/lib' '-lc' '-lm' '-Map=test_ad1836_driver.map'
GNU ld version 2.17
math_tools.o: In function `get_phase':
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:13: undefined reference to `__floatsidf'
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:13: undefined reference to `__fixdfsi'
math_tools.o: In function `get_magnitude':
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:8: undefined reference to `__floatsisf'
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:8: undefined reference to `__addsf3'
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:8: undefined reference to `__extendsfdf2'
/home/william/Development_new/Music_Recognition/code/uCLinux/uclinux-dist/user/blkfin-apps/icc_utils/example/DSP_imp/math_tools.c:8: undefined reference to `__fixdfsi'
/opt/uClinux/bfin-elf/bfin-elf/lib/libm.a(w_atan2.o): In function `atan2':
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:96: undefined reference to `__eqdf2'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:96: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__eqdf2'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:107: undefined reference to `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:107: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:110: undefined reference to `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_atan2.c:110: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__errno'
/opt/uClinux/bfin-elf/bfin-elf/lib/libm.a(w_sqrt.o): In function `sqrt':
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:71: undefined reference to `__ltdf2'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:71: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__ltdf2'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:79: undefined reference to `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:79: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:83: undefined reference to `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:83: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:86: undefined reference to `__errno'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/w_sqrt.c:86: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__errno'
/opt/uClinux/bfin-elf/bfin-elf/lib/libm.a(e_atan2.o): In function `_ieee754_atan2':
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:75: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:75: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:116: undefined reference to `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:116: relocation truncated to fit: R_BFIN_PCREL24 against undefined symbol `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:127: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:127: additional relocation overflows omitted from the output
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_atan2.c:125: undefined reference to `__subdf3'
/opt/uClinux/bfin-elf/bfin-elf/lib/libm.a(e_sqrt.o): In function `_ieee754_sqrt':
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_sqrt.c:110: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_sqrt.c:110: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_sqrt.c:117: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/e_sqrt.c:117: undefined reference to `__divdf3'
/opt/uClinux/bfin-elf/bfin-elf/lib/libm.a(s_atan.o): In function `atan':
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:169: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:170: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:172: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:172: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:173: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:173: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:176: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:176: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:176: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:145: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:150: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:150: undefined reference to `__gtdf2'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:157: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:157: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:157: undefined reference to `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:174: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:174: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:174: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:163: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:163: undefined reference to `__muldf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:163: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:163: undefined reference to `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:165: undefined reference to `__divdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:159: undefined reference to `__subdf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:159: undefined reference to `__adddf3'
/usr/src/packages/BUILD/blackfin-toolchain-2010R1/gcc-4.3/newlib/libm/math/s_atan.c:159: undefined reference to `__divdf3'
make: *** [test_ad1836_driver] Error 1
the code is the following:
#include <stdlib.h>
#include <math.h>
#include "math_tools.h"
short get_magnitude(re,im)
    return (short) sqrt((float)(re*re)+(float)(im*im));
short get_phase(re,im)
    return (short) atan2((double)im,(double)re);
