AD9371 Tx to Rx Isolation
Question asked by gavolbs on Dec 7, 2017
Latest reply on Dec 7, 2017 by gavolbs
The System Development User Guide UG-992 RevB page 273 gives the following isolation values for the ADRV9371-N/PCBZ Evaluation Card
Tx to Tx: 80 dB out to 6 GHz
Tx to Rx: 80 dB out to 6 GHz
Rx to Rx: 60 dB out to 6 GHz
ORx to ORx: 60 dB out to 6 GHz
These values are significantly better than the typical values given in the AD9371 Integrated, Dual RF Transceiver Datasheet on page 6:
Tx1 to Rx1 Signal Isolation and Tx2 to Rx2 Signal Isolation
700 MHz LO   68  dB
2600 MHz LO   68  dB
3500 MHz LO   62  dB
5500 MHz LO   60  dB
Tx1 to Rx2 Signal Isolation and Tx2 to Rx1 Signal Isolation
700 MHz LO   70  dB
2600 MHz LO   70  dB
3500 MHz LO   62  dB
5500 MHz LO   60  dB
Rx1 to Rx2 Signal Isolation
700 MHz LO   60  dB
2600 MHz LO   60  dB
3500 MHz LO   60  dB
5500 MHz LO
The difference in the UG-992 and datasheet values would suggest that isolation can be significantly improved with careful power distribution and PCB layout.
Could you provide clarification on the level of isolation we should be able to achieve assuming we following the design procedures given in UG-992.
Thanks
Gavin
