ADV7604: IO map register 0x33
Question asked by mra on Nov 14, 2011
Latest reply on Nov 27, 2011 by mra
In ADV7604IO_ADV7604CP_ADV7604AFE_ADV7604HDMI_ADV7341B-VER.1.4c_RevA.txt some of the scripts set IO map register 0x33 to 0x40, while some set the register to 0x60. In the "Revision History" under "1.1c" it is written "Add write 40 33 60 to enable LLC DLL mux". LLC DLL mux enable is IO map 0x33 [6], but I can not find any documentation for IO map 0x33 [5]. When should we set bit 5?
On "ADV7604 Design Support Files" (http://ez.analog.com/docs/DOC-1545) the script file is compressed into a zip file. Since the file only contains text, I think it would be better if you posted the content of the file with the FAQ template on this forum and linked to it from the "ADV7604 Design Support Files". Then it would be easier to see the difference between the new revisions of the file, since a revision diff tool is built into the FAQ template.
          Mats Randgaard
