ADuC7126 PWM Demo code doesn't work correctly
Question asked by Guanhan on Nov 29, 2017
Hi everyone
I assign the single channel PWM.
But I found the PWM didn't work  when I try to config the PWM to use the P2.1.
Here are the code that I assign:
int main(void)
#define GPIO_PIN1_PINFNUC_SELECT01  (0x00000010)
#define GPIO_Pin1_IOState       0x020000
#define GPIO_Pin1_Outputmode    (0x02000000)
#define PWM_PWMEN                               (0x0001)
#define PWM_CLOCK_PRESCALER_UCLKDIV256          (0x01C0)
#define PWM_TRIP_Interrupt_EN                   (0x0400)
GP2CON =    (  GPIO_PIN1_PINFNUC_SELECT01 );
GP2DAT =     (  GPIO_Pin1_IOState | GPIO_Pin1_Outputmode );
PWMCON0 = ( PWM_PWMEN | PWM_CLOCK_PRESCALER_UCLKDIV256 | PWM_TRIP_Interrupt_EN);
 while (1)
       if(PWM_Interrupt_State)
           PWM0COM0 = 0x08;          //high
           PWM0COM1 = 0x64;          //low
           PWM0COM2 = 0x01;          //high
           PWM0LEN  = 0x64;          //low
           PWM_Interrupt_State = false;
void IRQ_Handler(void) __irq
#define Interrupt_PWM_Trip                   (0x2000000)
 unsigned long IRQSTATUS = 0;
   IRQSTATUS = IRQSTA;
   if((IRQSTATUS & Interrupt_PWM_Trip) !=0)
        PWMCLRI = 0xFF;     // Clear the PWM trip interrupt source
        PWM_Interrupt_State = true;
//End
BTW, I had used Demo code of the  ADuC7xxxV0.2 folders.
 I tried the PWMTest.c ,PWMSignalTest.c and PWM Signal Generator.c File for test .
After that I found the code had the error in the config description
here are the error sentence that I found :
PWMCON    = BIT0 + BIT10;     // PWM Standard mode, UCLK/2, PWM Trip interrupt enabled
//End
And I tried to change the Config register description to PWMCON0
But It didn't make PWM work ,either
 I will Add the Demo code  files in the end
If anyone tell me  where is mistake in the code, also inside ADuc 7xxxV0.2 demo code.
I will very appreciate if anyone  help.
Written by Guanhan_Chen
2017/11/29.
