video_test dump in 2011R1-RC1
Question asked by shekharlav on Nov 12, 2011
Latest reply on Jan 17, 2012 by Aaronwu
I am using a BF527 based board with 2011R1-RC1 distro and 2011R1-RC2 toolchain.
I was trying to test my LCD using video Test.
Hence I followed the following procedure:
root:/> modprobe bfin-lq035q1-fb
bfin-lq035q1 bfin-lq035q1: 320x240 16-bit RGB FrameBuffer initialized
root:/> video_test
I have enabled LQ035Q1 as loadable module in the configuration file using "make menuconfig"
The application runs and I can see the "Infinity Figure" (same as 2010R1 ) on the LCD screen. But I also get a dump on my console.
------------[ cut here ]------------
WARNING: at drivers/gpio/gpiolib.c:1580
Modules linked in: bfin_lq035q1_fb cfbimgblt cfbcopyarea cfbfillrect
ADSP-BF527-0.2 500(MHz CCLK) 100(MHz SCLK) (mpu off)
Linux version 3.0.8-ADI-2011R12011R1-RC1_1_8_KA_CL (karthikeyan@tll.localdomain1
SEQUENCER STATUS:               Not tainted
SEQSTAT: 00000021  IPEND: 8008  IMASK: ffff  SYSCFG: 0006
  EXCAUSE   : 0x21
  physical IVG3 asserted : <0xffa00710> { _trap + 0x0 }
  physical IVG15 asserted : <0xffa00f4c> { _evt_system_call + 0x0 }
  logical irq   6 mapped  : <0x000065f4> { _bfin_coretmr_interrupt + 0x0 }
  logical irq  13 mapped  : <0x02092158> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cu}
  logical irq  15 mapped  : <0x00151700> { _err_handler + 0x0 }
  logical irq  21 mapped  : <0x000ff33c> { _bfin_rtc_interrupt + 0x0 }
  logical irq  23 mapped  : <0x00151a04> { _rx_handler + 0x0 }
  logical irq  24 mapped  : <0x001519a8> { _tx_handler + 0x0 }
  logical irq  27 mapped  : <0x001019a0> { _bfin_twi_interrupt_entry + 0x0 }
  logical irq  31 mapped  : <0x000b5368> { _bfin_serial_dma_rx_int + 0x0 }
  logical irq  32 mapped  : <0x000b50dc> { _bfin_serial_dma_tx_int + 0x0 }
  logical irq  35 mapped  : <0x000d611c> { _bfin_mac_interrupt + 0x0 }
  logical irq  59 mapped  : <0x000f43b8> { _blackfin_interrupt + 0x0 }
  logical irq  62 mapped  : <0x000f3f34> { _dma_controller_irq + 0x0 }
  logical irq 116 mapped  : <0x000336e8> { _irq_default_primary_handler + 0x0 }
  logical irq 117 mapped  : <0x000336e8> { _irq_default_primary_handler + 0x0 }
  logical irq 118 mapped  : <0x000336e8> { _irq_default_primary_handler + 0x0 }
RETE: <0x00000000> /* Maybe null pointer? */
RETN: <0x02badce8> /* kernel dynamic memory */
RETX: <0x00000480> /* Maybe fixed code section */
RETS: <0x020923a2> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x31a }
PC  : <0x000a48fa> { ___gpio_set_value + 0x2a }
DCPLB_FAULT_ADDR: <0x026ede6c> /* kernel dynamic memory */
ICPLB_FAULT_ADDR: <0x000a48fa> { ___gpio_set_value + 0x2a }
PROCESSOR STATE:
R0 : 00000003    R1 : 00000001    R2 : 00000001    R3 : 00000000
R4 : 00000026    R5 : 02b7080c    R6 : ffc01000    R7 : 00006e44
P0 : 00000050    P1 : 026ede48    P2 : 0024c8ec    P3 : 00006ed8
P4 : 00006af0    P5 : 00240420    FP : 02b70a50    SP : 02badc0c
LB0: 0009def0    LT0: 0009def0    LC0: 00000000
LB1: 00006a2c    LT1: 00006a1e    LC1: 00000000
B0 : 00000137    L0 : 00000000    M0 : fffffffc    I0 : 0005251a
B1 : 000000c0    L1 : 00000000    M1 : 00000001    I1 : 02aad000
B2 : 7ffff000    L2 : 00000000    M2 : 00001802    I2 : 00000003
B3 : 00000000    L3 : 00000000    M3 : 0000005b    I3 : 00000007
A0.w: 0000000e   A0.x: 00000000   A1.w: 0000000e   A1.x: 00000000
USP : 02adfd98  ASTAT: 02003004
---[ end trace 1091c2e644b080de ]---
Disabling lock debugging due to kernel taint
Hardware Trace:
   0 Target : <0x00003fdc> { _trap_c + 0x0 }
     Source : <0xffa006a4> { _exception_to_level5 + 0xa4 } JUMP.L
   1 Target : <0xffa00600> { _exception_to_level5 + 0x0 }
     Source : <0xffa004b4> { _bfin_return_from_exception + 0x18 } RTX
   2 Target : <0xffa0049c> { _bfin_return_from_exception + 0x0 }
     Source : <0xffa00558> { _ex_trap_c + 0x74 } JUMP.S
   3 Target : <0xffa004e4> { _ex_trap_c + 0x0 }
     Source : <0xffa0076a> { _trap + 0x5a } JUMP (P4)
   4 Target : <0xffa00710> { _trap + 0x0 }
      FAULT : <0x000a48fa> { ___gpio_set_value + 0x2a } BUG
     Source : <0x000a48e8> { ___gpio_set_value + 0x18 } IF !CC JUMP pcrel
   5 Target : <0x000a48d0> { ___gpio_set_value + 0x0 }
     Source : <0x020923a0> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x318 })
   6 Target : <0x02092380> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2f8 }
     Source : <0x00006a82> { _enable_gptimers + 0x26 } RTS
   7 Target : <0x00006a5c> { _enable_gptimers + 0x0 }
     Source : <0x0209237e> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2f6 })
   8 Target : <0x02092356> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2ce }
     Source : <0x00006b14> { _set_gptimer_config + 0x24 } RTS
   9 Target : <0x00006af0> { _set_gptimer_config + 0x0 }
     Source : <0x02092354> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2cc })
  10 Target : <0x0209234e> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2c6 }
     Source : <0x00006efe> { _set_gptimer_pwidth + 0x26 } RTS
  11 Target : <0x00006ed8> { _set_gptimer_pwidth + 0x0 }
     Source : <0x0209234c> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2c4 })
  12 Target : <0x02092346> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2be }
     Source : <0x00006e6a> { _set_gptimer_period + 0x26 } RTS
  13 Target : <0x00006e44> { _set_gptimer_period + 0x0 }
     Source : <0x02092344> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2bc })
  14 Target : <0x0209233c> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2b4 }
  15 Target : <0x00006af0> { _set_gptimer_config + 0x0 }
     Source : <0x0209233a> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x2b2 })
To end the application I do "Ctrl + \"
This results in another dump:
^\------------[ cut here ]------------
SEQUENCER STATUS:               Tainted: P
SEQSTAT: 00060021  IPEND: 8008  IMASK: ffff  SYSCFG: 0006
  EXCAUSE   : 0x21
RETN: <0x02badc38> /* kernel dynamic memory */
RETS: <0x02092244> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x1bc }
PROCESSOR STATE:
R0 : 00000003    R1 : 00000000    R2 : 00000000    R3 : 026f2b0c
R4 : ffffffc0    R5 : 0000000c    R6 : 00000001    R7 : 02b7080c
P0 : 00000050    P1 : 026ede48    P2 : 0024c8ec    P3 : 02986bd4
P4 : 02bafb64    P5 : 02b70800    FP : 00000000    SP : 02badb5c
LB0: 0009de14    LT0: 0009de12    LC0: 00000000
LB1: 0001a6e2    LT1: 0001a6e2    LC1: 00000000
B0 : 00000000    L0 : 00000000    M0 : 00000001    I0 : 00000000
B1 : 00000000    L1 : 00000000    M1 : 00000001    I1 : ffffffff
B2 : 7ffff000    L2 : 00000000    M2 : 00001802    I2 : 00000000
B3 : 00000000    L3 : 00000000    M3 : 0000005b    I3 : 000003ff
A0.w: 00000024   A0.x: 00000000   A1.w: 00000024   A1.x: 00000000
USP : 02adfc94  ASTAT: 02003044
---[ end trace 1091c2e644b080df ]---
Hardware Trace:
<5>   3 Target : <0xffa004e4> { _ex_trap_c + 0x0 }
     Source : <0x02092242> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x1ba })
   6 Target : <0x02092238> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x1b0 }
     Source : <0x020921e4> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x15c })
   7 Target : <0x020921d4> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x14c }
     Source : <0x020921ca> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x142 }
   8 Target : <0x020921b4> { :bfin_lq035q1_fb:_bfin_lq035q1_fb_cursor + 0x12c }
     Source : <0x000a64cc> { _fb_release + 0x24 } CALL (P1)
   9 Target : <0x000a64be> { _fb_release + 0x16 }
     Source : <0x001ada8e> { _mutex_lock + 0x36 } RTS
  10 Target : <0x001ada64> { _mutex_lock + 0xc }
     Source : <0x001acff8> { __cond_resched + 0x20 } RTS
  11 Target : <0x001acff2> { __cond_resched + 0x1a }
     Source : <0x001acfea> { __cond_resched + 0x12 } IF CC JUMP pcrel (BP)
  12 Target : <0x001acfd8> { __cond_resched + 0x0 }
     Source : <0x001ada60> { _mutex_lock + 0x8 } JUMP.L
  13 Target : <0x001ada58> { _mutex_lock + 0x0 }
     Source : <0x000a64ba> { _fb_release + 0x12 } JUMP.L
  14 Target : <0x000a64a8> { _fb_release + 0x0 }
     Source : <0x0004a946> { _fput + 0x76 } CALL (P2)
  15 Target : <0x0004a924> { _fput + 0x54 }
     Source : <0x0004a91c> { _fput + 0x4c } IF CC JUMP pcrel
QUIT
What could be the cause of these dumps even when the image on the LCD screen is correct.
Shekhar
