AD9364 ADC LSB voltage
Question asked by hitanvil on Nov 17, 2017
Latest reply on Nov 20, 2017 by Vinod
Can anyone provide the LSB voltage value of AD9364's receiving ADC or its input dynamic range? Its data sheet said  " Two high dynamic range ADCs digitize the received I and Q signals and pass them through configurable decimation filters and 128-tap FIR filters to produce a 12-bit output signal at the appropriate sample rate." And receiver section said that the ADC is 12-bit sigma-delta ADC. But no matter I did not find a direct description of its accuracy or dynamic range in voltage. I need this value to make some estimation for gain setting. Thanks a lot. the LSB voltage I need is the result after decimation, i.e., 12-bit ADC output's LSB equivalent voltage.
And when ADC output is12-bit, what's the sampling rate the ADC support?
