Clock Powerup timing
Question asked by philipj451 on Nov 16, 2017
Latest reply on Nov 22, 2017 by DaveThib
I have a design using ADAU1452 processor, the power for which may be turned on/off by a control CPU. The XTALIN pin is driven at 24.576MHz from an FPGA which also runs from the same on/off power lines as the ADAU1452.
My first question is:
Is it OK to power up the chip and then apply the XTALIN clock signal a short while later? It takes a second or two to program the FPGA and only then does the clock get established.
2nd question:
I am using the SPI slave interface to load the program etc. Is there a suitable register I can read before I do this that will contain a known value to confirm the chip s powered up and running? At the moment I am reading PLL_CTRL0 (address 0xF000) which says in the data sheet should have a reset value of 0x0060 but I am getting 0x0000...
Thanks anyone for any advice you can offer
PhilipJ
