ADXL362 and Arduino Uno giving zero output for acceleration and temp with SimpleRead
Question asked by designSTROM on Nov 3, 2017
Latest reply on Nov 6, 2017 by jwang
Hi, so I wired up an ADXL362 accelerometer w/ breakout from Sparkfun to work with an arduino uno. To power the sensor I have 3.3V output from the arduino going to the  V input of the ADXL362 and arduino ground going to the sensor ground. Also I level shifted pins 9-11 of the arduino from 5V to 3.3V using a voltage divider and plugged those into CS, SCK, and MOSI. The MISO output from the sensor is wired directly into pin 12 of the arduino. When I try to run the SimpleRead example code from the library I get zero output for all measurements as seen below. I also tried connecting the MISO through a fourth voltage divider but I still could not read anything. I'm not sure if it's just a wiring issue or a coding issue. I am just loading up the SimpleRead sketch and pressing upload. Any advice is appreciated!
Sensor output:
X=0. Y=0. Z=0. TEMP=0
Photo of connection circuit
