axi_dmac in loopback (dac_dma output to adc_dma input)
Question asked by Aban on Oct 30, 2017
Latest reply on Oct 31, 2017 by Aban
I have a picozed SDR board with ADI Linux running on it and we are able to stream through AD9361, using libiio ad9361_iiostream.c and osc.c application
Is it possible to test putting axi_dmac in simple loopback.  In the FPGA we have dac_dma with FIFO output interface and adc_dma with FIFO input interface.  I connected the dac_dma/fifo_rd_dout to adc_dma/fifo_wr_dout and dac_dma/fifo_rd_valid to adc_dma/fifo_wr_en. There are 2 more signals which were used. dac_dma/fifo_rd_en (input ) and adc_dma/fifo_wr_sync. I tied wr_sync signal to 1'b1 as we we have 2 channels( I and q each) and 64bit data bus.
I tied fifo_rd_en to 1'b1. Is above setup okay? Should I put both of them at same clock ?Lars
Configuration in TCL script:
set axi_ad9361_dac_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_ad9361_dac_dma]
set_property -dict [list CONFIG.DMA_TYPE_SRC {0}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.DMA_TYPE_DEST {2}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.CYCLIC {1}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.SYNC_TRANSFER_START {0}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.AXI_SLICE_SRC {0}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.AXI_SLICE_DEST {1}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.DMA_2D_TRANSFER {0}] $axi_ad9361_dac_dma
set_property -dict [list CONFIG.DMA_DATA_WIDTH_DEST {64}] $axi_ad9361_dac_dma
set axi_ad9361_adc_dma [create_bd_cell -type ip -vlnv analog.com:user:axi_dmac:1.0 axi_ad9361_adc_dma]
set_property -dict [list CONFIG.DMA_TYPE_SRC {2}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.DMA_TYPE_DEST {0}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.CYCLIC {0}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.SYNC_TRANSFER_START {1}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.AXI_SLICE_SRC {0}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.AXI_SLICE_DEST {0}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.DMA_2D_TRANSFER {0}] $axi_ad9361_adc_dma
set_property -dict [list CONFIG.DMA_DATA_WIDTH_SRC {64}]  $axi_ad9361_adc_dma
ad_connect  sys_cpu_clk axi_ad9361_adc_dma/fifo_wr_clk
ad_connect  util_ad9361_adc_pack/adc_valid axi_ad9361_adc_dma/fifo_wr_en
ad_connect  util_ad9361_adc_pack/adc_sync axi_ad9361_adc_dma/fifo_wr_sync
ad_connect  util_ad9361_adc_pack/adc_data axi_ad9361_adc_dma/fifo_wr_din
ad_connect  axi_ad9361_adc_dma/fifo_wr_overflow util_ad9361_adc_fifo/dout_ovf
ad_connect  axi_ad9361_clk axi_ad9361_dac_dma/fifo_rd_clk
ad_connect  util_ad9361_dac_upack/dac_valid axi_ad9361_dac_dma/fifo_rd_en
ad_connect  util_ad9361_dac_upack/dac_data axi_ad9361_dac_dma/fifo_rd_dout
ad_connect  axi_ad9361_dac_dma/fifo_rd_underflow axi_ad9361/dac_dunf
