ADXL372 data incorrect
Question asked by luutay on Oct 30, 2017
Latest reply on Apr 5, 2018 by NeerajSingla
Hello everybody,
I have a problem.
I'm using a PIC to work with ADXL372 Accelerometer , using SPI protocol.
Now i can read correct value in register 0x00~0x03 but I not move adxl372, the value in register XDATA_L, YDATA_L, ZDATA_L is alway change.
SPI frequency:4 MhzSPI_MODE_0.
I configurated for adxl372:
-THRESH_ACT_X_L(0X24): set 0xA3 // set therhold 0.5g
-THRESH_ACT_X_L(0X26) :set 0xA1  // set therhold 0.5g
-THRESH_ACT_X_L(0X28): set 0xA1  // set therhold 0.5g
-POWER_CTL( 0x3F): set 0x17// measure mode My configuration is correct ?
I need to configure anything else?
This is result when i use 1 byte Read to read value:
devid_ad (0X00) AD
devid_mst (0X01) 1D
devid_product (0X02) FA
revid (0X03) 02
status (0X04) 41
status2(0X05)  20
REGISTER 0X24 a3
REGISTER 0X26 a1
REGISTER 0X28 a1
power control (0X3F) 17
X_high=00 X_low=a0 Y_high=ff Y_low=f0  Z_high=00  Z_low=b0
X_high=01 X_low=00 Y_high=00 Y_low=f0  Z_high=01  Z_low=00
X_high=01 X_low=00 Y_high=ff Y_low=10  Z_high=01  Z_low=60
X_high=01 X_low=40 Y_high=ff Y_low=00  Z_high=02  Z_low=00
X_high=00 X_low=30 Y_high=ff Y_low=10  Z_high=00  Z_low=f0
X_high=01 X_low=a0 Y_high=ff Y_low=f0  Z_high=01  Z_low=00
X_high=01 X_low=00 Y_high=00 Y_low=f0  Z_high=01  Z_low=70
X_high=00 X_low=80 Y_high=ff Y_low=d0  Z_high=01  Z_low=70
X_high=00 X_low=30 Y_high=ff Y_low=00  Z_high=01  Z_low=80
X_high=00 X_low=80 Y_high=ff Y_low=00  Z_high=00  Z_low=80
X_high=01 X_low=00 Y_high=ff Y_low=f0  Z_high=01  Z_low=c0
X_high=00 X_low=a0 Y_high=fe Y_low=f0  Z_high=00  Z_low=00
X_high=00 X_low=30 Y_high=ff Y_low=f0  Z_high=01  Z_low=80
X_high=00 X_low=80 Y_high=ff Y_low=00  Z_high=00  Z_low=f0
X_high=00 X_low=30 Y_high=ff Y_low=e0  Z_high=01  Z_low=d0
This is result when i use Mulitbyte  Read to read value:
devid_ad (0X00) AD
devid_mst (0X01) 1D
revid (0X03) 02
status (0X04) 41
status2(0X05)  20
REGISTER 0X24 a3
REGISTER 0X26 a1
REGISTER 0X28 a1
X_high=01 X_low=40 Y_high=ff Y_low=f0  Z_high=00  Z_low=b0
X_high=00 X_low=f0 Y_high=ff Y_low=f0  Z_high=01  Z_low=00
X_high=02 X_low=00 Y_high=ff Y_low=f0  Z_high=00  Z_low=f0
X_high=00 X_low=90 Y_high=ff Y_low=80  Z_high=01  Z_low=00
X_high=00 X_low=30 Y_high=ff Y_low=f0  Z_high=01  Z_low=00
X_high=01 X_low=80 Y_high=ff Y_low=80  Z_high=01  Z_low=a0
X_high=00 X_low=f0 Y_high=fe Y_low=f0  Z_high=01  Z_low=70
X_high=00 X_low=80 Y_high=00 Y_low=00  Z_high=00  Z_low=f0
X_high=01 X_low=80 Y_high=ff Y_low=00  Z_high=01  Z_low=00
X_high=01 X_low=40 Y_high=ff Y_low=10  Z_high=01  Z_low=00
X_high=00 X_low=f0 Y_high=ff Y_low=f0  Z_high=02  Z_low=20
X_high=02 X_low=00 Y_high=ff Y_low=f0  Z_high=01  Z_low=00
X_high=00 X_low=00 Y_high=00 Y_low=00  Z_high=01  Z_low=00
X_high=00 X_low=80 Y_high=00 Y_low=00  Z_high=01  Z_low=00
X_high=00 X_low=30 Y_high=ff Y_low=10  Z_high=00  Z_low=80
X_high=01 X_low=70 Y_high=ff Y_low=f0  Z_high=02  Z_low=80
X_high=01 X_low=c0 Y_high=ff Y_low=f0  Z_high=01  Z_low=00
X_high=01 X_low=80 Y_high=ff Y_low=f0  Z_high=00  Z_low=f0
X_high=00 X_low=f0 Y_high=fe Y_low=f0  Z_high=00  Z_low=30
X_high=00 X_low=80 Y_high=fe Y_low=b0  Z_high=00  Z_low=50
X_high=00 X_low=00 Y_high=fe Y_low=f0  Z_high=00  Z_low=f0
X_high=00 X_low=f0 Y_high=ff Y_low=f0  Z_high=01  Z_low=e0
- this is function read and write for adxl372:
**           write 1 byte to adxl372
void SPI_ADXL372_WRITE (BYTE adress, BYTE data) {
   unsigned char TempAddress;
   TempAddress = adress;
   TempAddress = TempAddress << 1;
   output_low(SS);      //CS4 = LOW
   delay_ms(1);            //CS to SCLK set up time
   spi_write(TempAddress);      //write adress
   spi_write(data);
   delay_ms(1);
   output_high(SS);      //CS4 = High
   delay_ms(1);             //Wait Time
**           read 1 byte from adxl372
unsigned char SPI_ADXL372_READ(BYTE adress) {
   unsigned char result;
   TempAddress += 1;
   spi_write(TempAddress);  //adress in read mode
   result = spi_read(0);       //Read 8bit data (Send Dummy data 0x00)
   return result;
**           read muti byte to adxl372
void SPI_ADXL372_M_READ(BYTE adress, BYTE RXCONT) {
   unsigned char   RXBYTE;
   TempAddress += 1;
   for(RXBYTE=0; RXBYTE<RXCONT; RXBYTE++)
      r_data[RXBYTE] = spi_read(0);   //Read 8bit data (Send Dummy data 0x00)
Please help me to fix this problem.
