AD9889B: No Video out and no TMDS out clocks
Question asked by sync on Nov 6, 2011
Latest reply on Nov 22, 2011 by DaveD
I am a new user of the AD9889B device , the chip is being used on a Daughter board made by Microtronix. I am using this daughter card, on an FPGA Devkit board. My video path is as below..
From PC’s video card (HDMI port) -->  AD9880 on the D-card --> FPGA design --> AD9889B on the D-Card --> Monitor
Currently I am not able to obtain register value dump from the device, however I am able to read/write to individual registers.
Following are my observation..
-         HPD bit is correct.
-         Device is being initialized with following values..
    0x41, 0x10,     // Power Up device
    0x15, 0x00,     // Input Video RGB/YCbCr 4:4:4
    0x16, 0x00,     // Output Video RGB 4:4:4, Style 1, Clock on rising edge
    0x44, 0xf8,     // Enable S/PDIF reciever
    0x45, 0x00,     // Output format RGB
//    0x46, 0x00,   // SCAN info DEFAULT
    0x46, 0x08,     // SCAN info 16:9 output
    0x17, 0x02,     // Input aspect ratio 16:9 - bit (0) generated internal DE
    0x0A, 0x1c,     // MCLK ratio x128 fs as per RX chip settings - Enable S/PDIF enable Mclk for both I2s and Mclk
//    0x0b, 0x4e,   // MCLK falling edge
    0x0b, 0x0e,     // MCLK rising edge
    0x0c, 0x00,     // I2S Audio disable
    0x98, 0x07,     // Reserved, required for correct operation -- changed to 0x07
    0x9C, 0x38,     // Reserved, required for correct operation
    0x9D, 0x61,     // Reserved, required for correct operation
    0x9F, 0x70,     // Reserved, required for correct operation
    0xA2, 0x87,     // Output drive strength, 0x87 needed for > 80MHz
    0xA3, 0x87,     // Output drive strength, 0x87 needed for > 80MHz
    0xBB, 0xFF,     // Reserved, required for correct operation
    0xAF, 0x06,     // Disable HDCP encryption - Select HDMI bit(1)
//    0xBA, 0x00,   // Capture phase adjustment 7:5 all others 0 (011 is positive edge, 111 is negative edge)
    0xBA, 0xe0,     // Capture phase adjustment 7:5 all others 0 (011 is positive edge, 111 is negative edge)
//    0xA1, 0x00,   // Enable HDMI TMDS channels (6:2) - to disable write 1's
    0xCF, 0x70      // Secondary register map address, change from 0x70 to resolve conflict with GPIO device (test)
-         I am providing 1920/1080 resolution from the Video Card, which the monitor, when connected directly identifies as 1080p.
-         A signal tap (embedded oscilloscope) in the FPGA is confirming that video going in and coming out is same, with few clocks latency. The design is currently in the  bypass mode. I also verified DE to be 1920 cycles long.
-         I have confirmed that clock, Syncs/DE and Data (on some lines only) are reaching the AD9889B, from the FPGA.
-         When I scoped TMDS clk+, I found only some +ve DC offset there and clk- was simply at GND level. Even with AC coupling I see no clocks on these lines, with scope at about 500 mV.
-         I noticed that reg 0x3E was reading back 0x40, which implies that AD9889B is detecting the format as 1080i.
I am running short on ideas to further debug this chip and would appreciate any help. Please advice which registers I must further check to ensure that the Device is correctly configured and I can get TMDS clocks.
Jaspal
