CN-0217 code issues
Question asked by sqarus on Oct 19, 2017
Latest reply on Oct 26, 2017 by musach
Hi.I am facing a problem. I have made the CN-0217 board.The program works well in Range1 .
What changes do i need to make in program so that it works well for all other ranges as well.See below a) and b) in program.I need to run the program in Range2,3 and 4 as well.Thank you
a)  Set Range 1, PGA gain 1
b) // 1. Standby '10110000' Mask D8-10 of avoid tampering with gains
#include "Wire.h"
#define button 2
#define OUTPUT 8
#define SLAVE_ADDR 0x0D
#define ADDR_PTR 0xB0
#define START_FREQ_R1 0x82
#define START_FREQ_R2 0x83
#define START_FREQ_R3 0x84
#define FREG_INCRE_R1 0x85
#define FREG_INCRE_R2 0x86
#define FREG_INCRE_R3 0x87
#define NUM_INCRE_R1 0x88
#define NUM_INCRE_R2 0x89
#define NUM_SCYCLES_R1 0x8A
#define NUM_SCYCLES_R2 0x8B
#define RE_DATA_R1 0x94
#define RE_DATA_R2 0x95
#define IMG_DATA_R1 0x96
#define IMG_DATA_R2 0x97
#define TEMP_R1 0x92
#define TEMP_R2 0x93
#define CTRL_REG 0x80
#define CTRL_REG2 0x81
#define STATUS_REG 0x8F
const float MCLK = 16.776*pow(10,6); // AD5933 Internal Clock Speed 16.776 MHz
const float start_freq = 5*pow(10,3); // Set start freq, < 100Khz
const float incre_freq = 10*pow(10,3); // Set freq increment
const int incre_num = 9; // Set number of increments; < 511
//const int incre_num = 0;
char state;
void setup() {
Wire.begin();
Serial.begin(115200);
Serial.print("Asslam-o-alaikum");
pinMode(button, INPUT);
pinMode(8,OUTPUT);
//nop - clear ctrl-reg
writeData(CTRL_REG,0x0);
//reset ctrl register
writeData(CTRL_REG2,0x10);
programReg();
void loop(){
runSweep();
digitalWrite(8, HIGH);
//delay(10000);
//digitalWrite(8, LOW);
//delay(10000);
//Read state and enter FSM
//programReg();
// runSweep();
// measureTemperature();
//if(Serial.available()>0) {
// state = Serial.read();
//FSM
// switch(state) {
// case 'A': //Program Registers
// programReg();
// break;
// case 'B': //Measure Temperature
// break;
//case 'C':
// runSweep();
// delay(1000);
// break;
/////Programming Device Registers/////
// Serial.flush();
void programReg(){
// Set Range 1, PGA gain 1
writeData(CTRL_REG,0x01);
// Set settling cycles
writeData(NUM_SCYCLES_R1, 0x07);
writeData(NUM_SCYCLES_R2, 0xFF);
// Start frequency of 1kHz
writeData(START_FREQ_R1, getFrequency(start_freq,1));
writeData(START_FREQ_R2, getFrequency(start_freq,2));
writeData(START_FREQ_R3, getFrequency(start_freq,3));
// Increment by 1 kHz
writeData(FREG_INCRE_R1, getFrequency(incre_freq,1));
writeData(FREG_INCRE_R2, getFrequency(incre_freq,2));
writeData(FREG_INCRE_R3, getFrequency(incre_freq,3));
// Points in frequency sweep (100), max 511
writeData(NUM_INCRE_R1, (incre_num & 0x001F00)>>0x08 );
writeData(NUM_INCRE_R2, (incre_num & 0x0000FF));
void runSweep() {
short re;
short img;
double freq;
double mag;
double phase;
double gain;
double Impedance;
double GF;
double FFW;
double wt;
double BF;
double tot = 0;
double magcount = 0;
double impcount = 0;
double avgmag;
double totimp = 0;
double avgimp;
int i=0;
programReg();
writeData(CTRL_REG,(readData(CTRL_REG) & 0x07) | 0xB0);
// 2. Initialize sweep
writeData(CTRL_REG,(readData(CTRL_REG) & 0x07) | 0x10);
// 3. Start sweep
writeData(CTRL_REG,(readData(CTRL_REG) & 0x07) | 0x20);
while((readData(STATUS_REG) & 0x07) < 4 ) { // Check that status reg != 4, sweep not complete
delay(100); // delay between measurements
int flag = readData(STATUS_REG)& 2;
if (flag==2) {
byte R1 = readData(RE_DATA_R1);
byte R2 = readData(RE_DATA_R2);
re = (R1 << 8) | R2;
R1 = readData(IMG_DATA_R1);
R2 = readData(IMG_DATA_R2);
img = (R1 << 8) | R2;
freq = start_freq + i*incre_freq;
mag = sqrt(pow(double(re),2)+pow(double(img),2));
tot = tot+mag;
magcount = magcount+1;
// GF = (1/.22)/19.06;
GF = (0.99/1200)/2500;
// GF = (0.5/1000)/1000;
// GF=1;
// Impedance = 1/(GF*mag); //
// if (Impedance < 100){//
// impcount = impcount+1;//
// totimp = totimp+Impedance;//
// phase = atan(double(img)/double(re));
// phase = (180.0/3.1415926)*phase; //convert phase angle to degrees
// Phase Calibration
// sys_phase = 118;
// phase = phase - sys_phase;
// gain=1;
gain=(1.0/100000)/2950;
//gain = (1.0/197760)/9786.98;
Impedance = 1/(gain*mag);
Serial.print("Frequency:");
Serial.print(freq/1000);
Serial.print(",kHz;");
Serial.print(" Magnitude: ");
Serial.print(mag);
Serial.print(",kOhm;");
Serial.print(" Impedance: ");
Serial.print(Impedance);
Serial.println(",");
Serial.print(" Reactance: ");
Serial.print(img);
// break; //TODO: for single run, remove after debugging
//Increment frequency
if((readData(STATUS_REG) & 0x07) < 4 ){
writeData(CTRL_REG,(readData(CTRL_REG) & 0x07) | 0x30);
i++;
avgmag = tot/magcount;
avgimp = totimp/impcount;
wt = 118/2.205;
FFW = (0.396*(pow(1.54,2)/(avgimp*1000))+0.143*wt+8.399)*1.37*2;
BF = ((wt-FFW)/wt)*100;
Serial.print(" Avg Mag: ");
Serial.print(avgmag);
Serial.print(",");
Serial.print(" Avg Impedance: ");
Serial.print(avgimp);
Serial.print(",");
Serial.print(" % Body Fat: ");
Serial.print(BF);
Serial.print(",");
//Power down
// writeData(CTRL_REG,0xA0);
writeData(CTRL_REG,(readData(CTRL_REG) & 0x07) | 0xA0);
void writeData(int addr, int data) {
Wire.beginTransmission(SLAVE_ADDR);
Wire.write(addr);
Wire.write(data);
Wire.endTransmission();
delay(1);
int readData(int addr){
int data;
Wire.write(ADDR_PTR);
Wire.write(addr);
delay(1);
Wire.requestFrom(SLAVE_ADDR,1);
if (Wire.available() >= 1){
data = Wire.read();
else {
data = -1;
delay(1);
return data;
boolean measureTemperature() {
// Measure temperature '10010000'
writeData(CTRL_REG, 0x90);
//TODO: necessary to write to second control register?
delay(10); // wait for 10 ms
//Check status reg for temp measurement available
int flag = readData(STATUS_REG)& 1;
if (flag == 1) {
// Temperature is available
int temperatureData = readData(TEMP_R1) << 8;
temperatureData |= readData(TEMP_R2);
temperatureData &= 0x3FFF; // remove first two bits
if (temperatureData & 0x2000 == 1) { // negative temperature
temperatureData -= 0x4000;
double val = double(temperatureData) / 32;
temperatureData /= 32;
Serial.print("Temperature: ");
Serial.print(val);
//Serial.write(176); //degree sign
Serial.println("C.");
// Power Down '10100000'
return true;
} else {
return false;
byte getFrequency(float freq, int n){
long val = long((freq/(MCLK/4)) * pow(2,27));
byte code;
switch (n) {
case 1:
code = (val & 0xFF0000) >> 0x10;
break;
case 2:
code = (val & 0x00FF00) >> 0x08;
break;
case 3:
code = (val & 0x0000FF);
break;
default:
code = 0;
return code;
