AD590JCPZ Connection
Product Number: AD590JCPZ
I have often used the AD590 sensor in the flatpack version, and this is my first time working with the  AD590JCPZ. The datasheet states, “TO ENSURE CORRECT OPERATION, THE EXPOSED PAD (EP) SHOULD BE LEFT FLOATING.”
I have two questions about this:
1) General question: could it be beneficial to thermally connect (i.e, with thermally conductive epoxy) the EP to the surface whose temperature I want to measure, in order to improve thermal contact? (i.e., only thermal connection, not electrical)
2) Specific question: for an application, I need to monitor the temperature of an IC. For this reason, I thought of placing a temperature sensor on the opposite side of the PCB, trying to improve thermal contact with vias etc. as much as possible. For this reason, it would be crucial to connect the EP to the vias, which should be GND in my case. So in this case, the EP would also be electrically connected. Does this cause an unreliable reading, or does it just not guarantee the reported accuracy? In the latter case, it wouldn't be a big problem because it's a rough measurement and I just want to estimate the IC temperature: my biggest problem is thermal coupling with the IC rather than sensor accuracy.
Many thanks,
Lorenzo
  • Hi Lorenzo,
    Question 1.  Yes, but as long as at the end of the day, the thermal pad is floating.
    Question 2.  Do not GND the pad.  You can do as you suggest with the vias going through the board to the other side, but keep any thermal structure you create electrically isolated.
    Richard
  • Hi Lorenzo,
    Richard
