As i am calculating the ptr values so i get the ptr values. so can you tell me how to calculate the obscurtion level per foot and sensitivity. if there is any formula tell me how to calculate it explain me through any example
ADPD188BI
Recommended for New Designs
The ADPD188BI is a complete photometric system for smoke
detection using optical dual wavelength technology. The module integrates a highly efficient photometric...
Datasheet
ADPD188BI on Analog.com
There is no direct way to correlation between obscuration and PTR values for all types of smoke as each type has different reflective properties, and there is a large reflectance componant in the way the optics work. However for a given typ of smoke obscuration and PTR track linearly. The ADSW_SMOKEALGO works by inteligently identifying the type of smoke and dynamically shifting the smoke thresholds.
as i saw this forum i get the idea to calculate the obscuration from ptr and obscuration sensitivity coefficient Calculation of PTR and the relationship between PTR and obscuration is this right way to calculate obscuration and as i know for sensitivity we can calculate through obscuration (n) - obscuration (n-1) is it right way to do it ?
