Using Max1978 Evaluation kit
Product Number: MAX1978
I am interested in using the MAX1978 Evaluation Kit for a temperature controller. You can find the kit details at this link:  https://www.analog.com/media/en/technical-documentation/data-sheets/MAX1978EVKIT.pdf
I would like to know if I can use the U209-005-DB25 connector, as seen here:  https://www.digikey.com/en/products/detail/tripp-lite/U209-005-DB25/5359338?s=N4IgTCBcDaIKpgAwE4C0jEFZUBEBCYmIAugL5A
 to connect the MAX1978 Evaluation Kit to my computer. My computer only has a USB port, so I need to confirm whether this connector would work for this setup.
If this connector is not suitable, could you please suggest an alternative connector or provide a detailed method for connecting the MAX1978 Evaluation Kit to my computer without the need for such connector?
Thank you for your assistance.
-Sophia
