Hi ADI Team,
AD5941
Recommended for New Designs
The AD5940 and AD5941 are high precision, low power analog front ends (AFEs) designed for portable applications that require high precision, electrochemical...
Datasheet
AD5941 on Analog.com
Hi ADI Team,
Hi, can a resolution be provided for this issue, id also like to add that I'm not sweeping over the frequencies, but measuring the impedance over a constant frequency
It may be due to ADC saturation. You may change pImpedanceCfg->HstiaRtiaSel at higher frequencies and check.
The function AD5940_GetFreqParameters() shows other parameters that can be updated with frequency to avoid saturation for the entire frequency range.
