Seeking Support for Reading ROM code of I-Button
Product Number: DS9092L
Dear AD Team,
                     In our custom board, we are using the DS9092L+ IButton probe with the DS1990A IButton interfaced with MSP432E4 Microcontroller. However, we are facing difficulties in reading the ROM code of the IButton.
Below are the connections for your reference:
  • IButton Probe:
o   Green (Data) connected to PORTE- E2 on the microcontroller
o   Black (+ve LED) connected to PORTE- E3 on the microcontroller
o   White (-ve LED) connected to GND
o   Red (Ground) connected to GND
Additionally, we have connected a 4.7kohm resistor for pull-up on the data line.
Problem Facing:
                          I can able to detect the I Button successfully but could not able to read the 64bit ROM code of the IButton.Reading ROM code i am sending 0x33 command to the I Button.
I Button code:
#ifdef I_BUTTON_INTERFACE
#if 1
    int index;
    led_init(); // Initialize the LED
    I_ButtonInit();
    /* Clear the buffer */
    memset(&DestBuff[0], 0x00, sizeof(DestBuff));
    while(1)
        onewire_reset();
        /* Find the One Wire device */
        Read_ROMCode(&DestBuff[0]);
        UARTprintf("OneWire ROMCode = ");
        for (index = 0; index < 8; index++)
            UARTprintf("0x%x ", DestBuff[index]);
        UARTprintf("\r\n");
        delayms(50);
#endif
void led_init() {
    UINT8 u8RetVal;
    u8RetVal = GPIO_Output_Init(SYSCTL_PERIPH_GPIOK,GPIO_PORTK_BASE,GPIO_PIN_4,GPIO_PIN_4);
    ROM_GPIOPinWrite(GPIO_PORTK_BASE, (GPIO_PIN_4), GPIO_PIN_4);
    delaySec(1);
    ROM_GPIOPinWrite(GPIO_PORTK_BASE, (GPIO_PIN_4), 0);
void I_ButtonInit()
    UINT8 u8RetVal;
    u8RetVal = GPIO_Output_Init(SYSCTL_PERIPH_GPION,GPIO_PORTN_BASE,GPIO_PIN_4,GPIO_PIN_4);//PN4 set as output
    ROM_GPIOPinWrite(GPIO_PORTN_BASE, (GPIO_PIN_4), GPIO_PIN_4); //making as high
unsigned int onewire_reset() {
    UINT8 u8RetVal;
    ROM_GPIOPinWrite(GPIO_PORTN_BASE, (GPIO_PIN_4), 0);//Making Data line as low
    delayus(480);
    ROM_GPIOPinWrite(GPIO_PORTN_BASE, (GPIO_PIN_4), GPIO_PIN_4);//Making Data line as high
    delayus(70);
    u8RetVal = GPIO_Input_Init(SYSCTL_PERIPH_GPION,GPIO_PORTN_BASE,GPION,GPIO_PIN_4,INT_GPION,GPIO_PULLUP_ENABLE,GPIO_FALLING_EDGE,GPIO_INT_DISABLE);//Data line configured as Input
    UINT32 presence = ROM_GPIOPinRead(GPIO_PORTN_BASE, GPIO_PIN_4);//Reading the data line status
    delayus(410);
    UARTprintf("\n");
    UARTprintf("Presesnce:%x\n",presence);
    if(presence == 0)
        UARTprintf("I_BUTTON DETECTED\n");
    else
        UARTprintf("I_BUTTON NOT DETECTED\n");
    GPIO_Output_Init(SYSCTL_PERIPH_GPION,GPIO_PORTN_BASE,GPIO_PIN_4,GPIO_PIN_4);//Data line configured as Output
void OneWire_WriteByte(char byte)
    int l;
    // Loop to write each bit in the byte, LS bit first
    for (l = 0; l < 8; l++)
        OneWire_WriteBit(byte & 0x01);
        byte >>= 1;
void OneWire_WriteBit(char bit)
    if (bit)
        // Write '0' bit for the WriteOne bit
        ROM_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_4, 0);
        delayus(6);
        ROM_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_4, GPIO_PIN_4);
        delayus(64);
    else
        // Write '0' bit for the WriteZero bit
        delayus(70);
        ROM_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_4, GPIO_PIN_4); //if not working change to 0 and check
        delayus(10);
unsigned char OneWire_Readbyte(void)
    int l;
    unsigned char result = 0;
        result |= (OneWire_Readbit() << l);
    return result;
unsigned char OneWire_Readbit(void)
    unsigned char result;
    UINT8 u8RetVal;
    /* Start the Read bit sequence */
    delayus(6);//    delayms(6);
    ROM_GPIOPinWrite(GPIO_PORTN_BASE, GPIO_PIN_4, GPIO_PIN_4);//if u want to make high uncomment it
    delayus(9);
    /* Make the pin as Input for reading the data */
    result = ROM_GPIOPinRead(GPIO_PORTN_BASE, GPIO_PIN_4);
    delayus(45);
    /* Revert back the GPIO state as ouput */
    return result;
void Read_ROMCode(unsigned char *destbuf)
    int n;
    if (NULL == destbuf)
        return;
        onewire_reset();
    OneWire_WriteByte(0x33);
    for (n = 0; n < 8; n++)
        destbuf[n] = OneWire_Readbyte();
When i keep I button on the probe some random value is coming,if I do not keep printing all 0xFF.
Ibutton Used:DS1990A.
Please let me know what will be the issue in reading ROM  code of the I Button.
