I tried to use the AD5941 eval-module (includes the EVAL-ADICUP3029) to read real and imaginary value of a resistor load (Impedance application), the resistor value is 220k ohm.
The setup :
The results :
You could see that the real value is negative, in real life negative value for real value of resistor is impossible, right? What does it mean?
I tried to probe the excitation signal at SE0, and obtained the following signal.
And why did not I obtain a sine-wave signal? What does this signal mean?
