Hi ADI Team,
I have tried using the AD5941 AFE to read open circuit potential of certain solutions but I have discovered that the analog pins that I am using for said measurement are heavily biased in the range of mV(using DMM) while the voltages I am trying to measure are in the range of microvolts, and hence the analog pins are biasing said solution and I am receiving erroneous readings.
I have the requirement to measure 5 different measurements wrt to a common reference so in total I need 6 pins and I have 3 AD5941 in my custom built PCB(heavily similar to the evaluation board)
Can I know why I am observing this behavior, will greatly appreciate your efforts to help me understand said issue.
Attached schematic to one of the AFE
The code I'm using is as follows
