MAX3443E
Production
The MAX3440E-MAX3444E fault-protected RS-485 and J1708 transceivers feature ±60V protection from signal faults on communication bus lines. Each device...
Datasheet
MAX3443E on Analog.com
Hi Experts ,
Good day ,
Can you please advise and share the PCN behind this package label format change with the parts ? I have noticed two types of formats maintaining at ANALOG DEVICES for the package label.
Looking forward for your valuable support on this.
Have a great day..
Thank you.
Ivan Paul
Hooman - Moved from Interface and Isolation to Temperature Sensors. Post date updated from Friday, June 14, 2024 4:50 PM UTC to Tuesday, August 6, 2024 6:34 PM UTC to reflect the move.
Hooman - Moved from Interface and Isolation to Temperature Sensors. Post date updated from Tuesday, August 6, 2024 6:34 PM UTC to Tuesday, August 6, 2024 6:34 PM UTC to reflect the move.
Hooman Can you please advise on this also?
There are two types of label coming in MAXIM products. Pls advise whether Analog devices have two format of package label ?
Also all other parameters are matching with each other and need PCN behind these changes .
Looking forward for your support.
Regards
Manoj Balakrishnan
Hi Manoj,
I'm asking around to see who can help you with this question since I'm not the right person.
Once I hear back, I'll keep you posted.
Hooman
Hi Hooman ,
Good Day ,
Can you please help me and send me relevant PCN for these changes in the label format ? I seen two type of format in Maxim Label.
Looking forward for your valuable support.
Thank you..
Regards
Manoj
Hi Manoj,
I've forwarded your question regarding the MAX30208 to the responsible Application Engineer. I hope they find an answer to your question and respond to you quickly.
Hooman
Thank you so much Hooman .
I will wait for your reply.
Hi Hooman ,
Any update on this query ?
Hi Manoj,
I was not able to find anybody to help you out with the MAX30208 Temp Sensor question that you had above.
So I moved the thread to the Temperature Sensor Q&A section to see if anybody has the answer to your question.
Hooman
Hi Manoj,
I got the following response related to the question you've posed about MAX30208 labeling:
"A PCN is issued for Form, Fit or Function of a part. Labeling does meet those requirements.
The label on the left looks like a shipment from Disti and the label on the right was shipped directly from Maxim according to our packaging team.
The label on the right includes additional information: the customer PO #, MSL #, and changed the name of the “lot” from lot to batch. The “seal date” is not on the label on the right."
Hope this answers some of your questions if not all.
Hooman
Hello Hooman ,
Hope you are doing good.
Please refer to below image having slight differences on the ADI label and let me know any PCN released on this changes.
Looking forward for your valuable support and advise on the acceptance.
Thank you..
Regards
Manoj Balakrishnan.
