Customer is working on MAX30210, customer would like to seek help from ADI for how to couple the sensor module to the skin? This is a contact skin temperature sensor, that means the sensor must make contact with skin or there should be coupling mechanism between sensor and the skin. How this coupling (mechanical integration) shall be done? The sensor will be mounted on PCB and will be housed in a ID.
Kindly help!
Naveen
