Hi
Can LTC2983 data memory (0x030~0x033) be read once and then read again ?
Will the data in LTC2983 data memory (0x030~0x033) disappear if it is not read for a few days?
Best regards
N.Kokubo
Hi
Best regards
N.Kokubo
Hi Kokubo,
The EEPROM able to save the contents of the user RAM even power cycles. The user just have to tell the LTC2983 to read the contents back from EEPROM into user RAM. For more information on the device EEPROM, you may check page 23 on LTC2983 datasheet.
Mae
Hi Mae san
LTC2983 does not have EEPROM.
Can LTC2983 data memory (0x030~0x033) be read once and then read again with the power kept on ?
Will the data in LTC2983 data memory (0x030~0x033) disappear if it is not read for a few days with the power kept on?
Best regards
N.Kokubo
Hi Kokubo san,
My apology, I was referring to LTC2984 device with EEPROM.
For the LTC2983, it uses a static RAM to store results. Data can be read multiple times as long as the power is kept on. Data is lost when power is removed.
Mae
Hi Mae san
Thank you for your reply.
Our cutomer is in trouble because the data may not be read out normally after not accessing LTC2983 for a long time. After the measurement start command, CS becomes L during conversion and SCK does not operate for some time. Is there any possibility that such an operation will cause a problem?
Best regards
N.Kokubo
Hi Kokubo san,
Can you send me the customer setup config, plots and application they are planning to do through my analog email account please?
Mae
Hi
I do not knwow your e-mail address.
My addrees is kokubo_nobuyuki@daitron.co.jp.
Please send your e-mail address to my address.
Best regards
N.Kokubo
Hi Mae san
Thank you for your support.
I do not know your accont address.
Could you inform it to my e-mail.
Best regards
N.Kokubo
Hi Kokubo san,
Please check your inbox, i just emailed you on the address you provided.
Mae
